GPU Gems 2 -Programming Techniques for High- Performance Graphics and General-Purpose Computation. 2005, ch. Terrain rendering using GPU-based geometry clipmaps, pp.109-122 ,
Realistic water volumes in real-time, Eurographics Workshop on Natural Phenomena Eurographics, 2006. ,
Rendering geometry with relief textures, Graphics Interface '06, 2006. ,
Tetrad volume and particle rendering in X2 An irradiance atlas for global illumination in complex production scenes, SIGGRAPH 2003 Sketches & Applications Rendering Techniques (Eurographics Symposium on Rendering -EGSR), pp.133-142, 2003. ,
Proximity clouds -an acceleration technique for 3D grid traversal, Vis. Comput, vol.11, issue.1, pp.27-38, 1994. ,
Painting and rendering textures on unparameterized models, SIGGRAPH'02, pp.763-768, 2002. ,
Rendering forest scenes in real-time, Rendering Techniques (Eurographics Symposium on Rendering -EGSR), pp.93-102, 2004. ,
High-quality pre-integrated volume rendering using hardware-accelerated pixel shading, ACM SIGGRAPH/EUROGRAPHICS workshop on Graphics hardware (HWWS), pp.9-16, 2001. ,
Heuristic Ray Shooting Algorithms Interactive k-d tree GPU raytracing, ACM Siggraph symposium on Interactive 3D graphics and games (I3D), pp.167-174, 2000. ,
http://portal.acm.org/ft_gateway.cfm?id=1242192. [Kap03] KAPLER A.: Avalanche! snowy FX for Adaptive texture maps, SIG- GRAPH 2002 Sketches and Applications SIGGRAPH 2003 Sketches & Applications ACM SIGGRAPH/EUROGRAPH- ICS conference on Graphics hardware (HWWS), pp.179-186, 2002. ,
Modeling and rendering of clouds on "stealth http://portal.acm.org/ft_gateway.cfm?id=1187214. [Kis98] KISACIKOGLU G.: The making of black-hole and nebula clouds for the motion picturèSphere´withSphere´with volumetric rendering and the f-rep of solids, SIGGRAPH 2005 Sketches SIGGRAPH 98 Conference abstracts and applications sketches, pp.85-289, 1998. ,
Unified Texture Management for Arbitrary Meshes http://www-evasion.imag.fr/Publications Geometry clipmaps: terrain rendering using nested regular grids, Tech. Rep. RR5210-, INRIA SIGGRAPH'04, pp.769-776, 2004. ,
Perfect spatial hashing, SIGGRAPH '06, pp.579-588, 2006. ,
GPU Gems 2 -Programming Techniques for High-Performance Graphics and General-Purpose Computation, pp.595-613, 2005. ,
Texture sprites: Texture elements splatted on surfaces, ACM-SIGGRAPH Symposium on Interactive 3D Graphics (I3D), 2005. ,
Pattern based procedural textures, ACM-SIGGRAPH Symposium on Interactive 3D Graphics (I3D), 2003. ,
Glift, ACM Transactions on Graphics, vol.25, issue.1, pp.1-60, 2006. ,
DOI : 10.1145/1122501.1122505
Modeling animating and rendering complex scenes using volumetric textures, IEEE Transactions on Visualization and Computer Graphics, vol.4, issue.1, pp.55-70, 1998. ,
Shell maps, SIG- GRAPH'05, pp.626-633, 2005. ,
An image synthesizer, SIGGRAPH'85, pp.287-296, 1985. ,
Advanced GPU raycasting, In Central European Seminar on Computer Graphics, pp.69-76, 2005. ,
Synthesis of bidirectional texture functions on arbitrary surfaces, Proceedings of ACM SIG- GRAPH, pp.665-672, 2002. ,
