New interface
Conference papers
Tree Automata with Global Constraints
Abstract : A tree automaton with global equality and disequality constraints, TAGED for short, is an automaton on trees which allows to test (dis)equalities between subtrees which may be arbitrarily faraway. In particular, it is equipped with an (dis)equality relation on states, so that whenever two subtrees t and t' evaluate (in an accepting run) to two states which are in the (dis)equality relation, they must be (dis)equal. We study several properties of TAGEDs, and prove decidability of emptiness of several classes. We give two applications of TAGEDs: decidability of an extension of Monadic Second Order Logic with tree isomorphism tests and of unification with membership constraints.
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/inria-00292027
Contributor : Emmanuel Filiot Connect in order to contact the contributor
Submitted on : Monday, June 8, 2009 - 1:43:07 PM
Last modification on : Friday, February 4, 2022 - 3:12:45 AM
Long-term archiving on: : Wednesday, September 22, 2010 - 1:01:04 PM
dlt-full.pdf
Identifiers
  • HAL Id : inria-00292027, version 2
Collections
Citation
Emmanuel Filiot, Jean-Marc Talbot, Sophie Tison. Tree Automata with Global Constraints. 12th International Conference on Developments in Language Theory (DLT), Sep 2008, Kyoto, Japan. pp.314-326. ⟨inria-00292027v2⟩
Share
Metrics
Record views
278
Files downloads
713
