Pseudo-Boolean Optimization, Discrete Appl. Math, vol.123, issue.1, pp.155-225, 2002. ,
Radio link frequency assignment, Constraints, vol.4, issue.1, pp.79-89, 1999. ,
DOI : 10.1023/A:1009812409930
A Maximal Tractable Class of Soft Constraints, Journal of Artificial Intelligence Research, vol.22, pp.1-22, 2004. ,
The complexity of soft constraint satisfaction, Artificial Intelligence, vol.170, issue.11, pp.983-1016, 2006. ,
DOI : 10.1016/j.artint.2006.04.002
Optimal soft arc consistency, Proc. of IJCAI-07, pp.68-73, 2007. ,
Arc consistency for soft constraints, Artificial Intelligence, vol.154, issue.1-2, pp.199-227, 2004. ,
DOI : 10.1016/j.artint.2003.09.002
Minimization of locally-defined submodular functions by Optimal Soft Arc Consistency Existential arc consistency : Getting closer to full arc consistency in weighted csps, Proc. of IJCAI-05, pp.84-89, 2005. ,
MiniMax- Sat : A New Weighted Max-SAT Solver, Proc. of SAT'2007, number 4501 in LNCS, pp.41-55, 2007. ,
Tractable constraints on ordered domains, Artificial Intelligence, vol.79, issue.2, pp.327-339, 1995. ,
DOI : 10.1016/0004-3702(95)00107-7
Temporal constraint reasoning with preferences ,
Solving the simple plant location problem by genetic algorithm, RAIRO - Operations Research, vol.35, issue.1, pp.127-142, 2001. ,
DOI : 10.1051/ro:2001107
Exploiting Unit Propagation to Compute Lower Bounds in Branch and Bound Max-SAT Solvers, Proc of CP-05, number 3709 in LNCS, pp.403-414, 2005. ,
DOI : 10.1007/11564751_31
New Lower Bounds of Constraint Violations for Over-Constrained Problems, Proc. of CP-01, number 2239 in LNCS, pp.332-345, 2001. ,
DOI : 10.1007/3-540-45578-7_23
Arc Consistency for Soft Constraints, Proc. of CP-00, pp.411-424, 2000. ,
DOI : 10.1007/3-540-45349-0_30
Valued constraint satisfaction problems : hard and easy problems, Proc. of IJCAI-95, pp.631-637, 1995. ,
Exact Solution of Permuted Submodular MinSum Problems In Energy Minimization Methods in Computer Vision and Pattern Recognition, LNCS, issue.4679, pp.28-38, 2007. ,
Sintaksicheskiy analiz dvumernykh zritelnikh signalovv usloviyakh pomekh (Syntactic analysis of two-dimensional visual signals in noisy conditions), Kibernetika, vol.4, pp.113-130, 1976. ,
A Linear Programming Approach to Max-Sum Problem: A Review, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.29, issue.7, pp.1165-1179, 2007. ,
DOI : 10.1109/TPAMI.2007.1036
A new local consistency for weighted CSP dedicated to long domains, Proceedings of the 2006 ACM symposium on Applied computing , SAC '06, pp.394-398, 2006. ,
DOI : 10.1145/1141277.1141367
