Identifying and exploiting problem structures using explanation-based constraint programming, Constraints, vol.11, issue.4, 2006. ,
DOI : 10.1007/s10601-006-9002-8
URL : https://hal.archives-ouvertes.fr/hal-00869105
Optimal soft arc consistency, IJCAI, pp.68-73, 2007. ,
Existential arc consistency : Getting closer to full arc consistency in weighted CSPs, IJCAI, pp.84-89, 2005. ,
Partial constraint satisfaction, pp.21-70, 1992. ,
Dual viewpoint heuristics for binary constraint satisfaction problems. ECAI, pp.31-35, 1992. ,
An empirical study of dynamic variable ordering heuristics for the constraint satisfaction problem, CP, pp.179-193, 1996. ,
DOI : 10.1007/3-540-61551-2_74
Limited discrepancy search, IJCAI, pp.607-615, 1995. ,
The PALM system : explantion-based constraint programming. Proceedings of TRICS a post-conference workshop of CP, pp.118-133, 2000. ,
Exploiting the use of DAC in MAX-CSP, Proceedings of CP, 1996. ,
DOI : 10.1007/3-540-61551-2_83
In the quest of the best form of local consistency for Weighted CSP, IJCAI, pp.239-244, 2003. ,
Combining VNS with constraint programming for solving anytime optimization problems, European Journal of Operational Research, vol.191, issue.3, pp.1-31, 2007. ,
DOI : 10.1016/j.ejor.2006.12.062
Impact-Based Search Strategies for Constraint Programming, CP, pp.557-571, 2004. ,
DOI : 10.1007/978-3-540-30201-8_41
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.461.1328
Valued constraint satisfaction problems : Hard and easy problems, IJCAI, pp.631-639, 1995. ,
Trying harder to fail first. ECAI, pp.249-253, 1998. ,
