Compression of correlated bit-vectors, Information Systems, vol.16, issue.4, pp.387-400, 1991. ,
DOI : 10.1016/0306-4379(91)90030-D
Spanning tree algorithms to some hard combinatorial problems, Proceedings of Optimization Days, pp.83-84, 1997. ,
Neighborhood searches for the bounded diameter minimum spanning tree problem embedded in a vns, ea, and aco, Proceedings of the Genetic and Evolutionary Computation Conference, pp.1187-1194, 2006. ,
Constraint-based local search, 2005. ,
Greedy heuristics for the bounded diameter minimum spanning tree problem, Journal of Experimental Algorithmics, vol.14, 2004. ,
DOI : 10.1145/1498698.1498699
A new evolutionary approach to the degree-constrained minimum spanning tree problem, IEEE Transactions on Evolutionary Computation, vol.4, issue.2, pp.125-134, 2000. ,
DOI : 10.1109/4235.850653
Comparison of algorithms for the degree constrained minimum spanning tree, Journal of Heuristics, vol.6, pp.587-611, 2001. ,
Comparison of algorithms for the degree constrained minimum spanning tree, Journal of Heuristics, pp.587-611, 2001. ,
Integer Programming Approaches to Facilities Layout Models with Forbidden Areas, Annals of Operations Research, vol.81, pp.405-417, 1998. ,
DOI : 10.1007/978-3-642-58891-4_13
Advances in linear and integer programming, Oxford Lecture Series in Mathematics and its Applications, 1996. ,
Finding all the best swaps of a minimum diameter spanning tree under transient edge failures [18] Kerry Raymond. A tree-based algorithm for distributed mutual exclusion, Journal of Graph Algorithms and Applications ACM Trans. Comput. Syst, vol.5, issue.71, pp.39-5761, 1989. ,
A hybrid aco algorithm for the capacitated minimum spanning tree problem, Proceedings of First International Workshop on Hybrid Metaheuristics, pp.1-10, 2004. ,
Improved heuristics for the bounded-diameter minimum spanning tree problem. Soft Computing -A Fusion of Foundations, Methodologies and Applications, pp.911-921, 2006. ,
Variable neighborhood search for the degree-constrained minimum spanning tree problem, Discrete Appl. Math, vol.118, pp.43-54, 2002. ,
A Lagrangean approach to the degree-constrained minimum spanning tree problem, European Journal of Operational Research, vol.39, issue.3, pp.325-331, 1989. ,
DOI : 10.1016/0377-2217(89)90169-0
Local search for the Steiner tree problem in the Euclidean plane, European Journal of Operational Research, vol.119, issue.2, pp.282-300, 1999. ,
DOI : 10.1016/S0377-2217(99)00131-9
A note on genetic algorithms for degree-constrained spanning tree problems, Networks, vol.30, issue.2, pp.91-95, 1997. ,
DOI : 10.1002/(SICI)1097-0037(199709)30:2<91::AID-NET3>3.0.CO;2-F
