An observability form for linear systems with unknown inputs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Control Année : 2006
In this paper is given a constructive algorithm that transforms a linear system with unknown inputs into a novel observability form. This form is useful to derive finite time observers even if the system does not satisfy some matching conditions usually required for the design of unknown input observers. The practical example of an aircraft subject to actuator faults is provided to show the efficiency of the approach.
Automatique
ijcuiohal.pdf (120.15 Ko) Télécharger le fichier
inria-00293831 , version 1 (07-07-2008)
Thierry Floquet, Jean-Pierre Barbot. An observability form for linear systems with unknown inputs. International Journal of Control, 2006, 79 (2), pp.132-139. ⟨10.1080/00207170500472909⟩. ⟨inria-00293831⟩
130 Consultations
545 Téléchargements
