Sliding mode observer for triangular input form, Proceedings of 35th IEEE Conference on Decision and Control, 1996. ,
DOI : 10.1109/CDC.1996.572727
Observability Normal Forms New trends in Nonlinear dynamics and control, LNCIS, vol.295, 2003. ,
Sliding observers for robot manipulators, Automatica, vol.27, issue.5, pp.859-864, 1991. ,
DOI : 10.1016/0005-1098(91)90041-Y
State and Input Estimation for a Class of Uncertain Systems, Automatica, vol.34, issue.6, pp.757-764, 1998. ,
DOI : 10.1016/S0005-1098(98)00013-2
Observation and identification of mechanical systems via second order sliding modes, th International Workshop on Variable Structure Systems, 2004. ,
Nonlinear flux sliding mode observer, IEEE CSCC99, 1999. ,
Sliding-mode observers based on equivalent control method, [1992] Proceedings of the 31st IEEE Conference on Decision and Control, 1992. ,
DOI : 10.1109/CDC.1992.371368
Sliding mode observers. Tutorial, Proceedings of 1995 34th IEEE Conference on Decision and Control, 1995. ,
DOI : 10.1109/CDC.1995.479009
The invariance conditions in variable structure systems, Automatica, vol.5, issue.3, pp.287-295, 1969. ,
DOI : 10.1016/0005-1098(69)90071-5
On the development of discontinuous observers, International Journal of Control, vol.26, issue.5, pp.1211-1229, 1994. ,
DOI : 10.1080/00207178708933870
Sliding mode control: theory and applications, 1998. ,
Sliding mode observers for fault detection and isolation, Automatica, vol.36, issue.4, pp.541-553, 2000. ,
DOI : 10.1016/S0005-1098(99)00177-6
A comparison of sliding mode and unknown input observers for fault reconstruction, IEEE Conf. on Decision and Control, 2004. ,
Sensor fault tolerant control using sliding mode observers, Control Engineering Practice, vol.14, issue.8 ,
DOI : 10.1016/j.conengprac.2005.05.002
URL : http://www.sciencedirect.com/science?_ob=ShoppingCartURL&_method=add&_eid=1-s2.0-S0967066105001449&originContentFamily=serial&_origin=article&_ts=1480324916&md5=c1b7a9fe83cd6028386f81a18cf136d2
A sliding mode approach of unknown input observers for linear systems, 2004 43rd IEEE Conference on Decision and Control (CDC) (IEEE Cat. No.04CH37601), 2004. ,
DOI : 10.1109/CDC.2004.1430293
On the robust fault detection via a sliding mode disturbance observer, International Journal of Control, vol.4, issue.7, pp.622-629, 2004. ,
DOI : 10.1016/0005-1098(76)90041-8
URL : https://hal.archives-ouvertes.fr/hal-00762283
Higher order sliding modes, Sliding Mode Control in Engineering, Marcel Dekker, pp.53-101, 2002. ,
Fault diagnostics using sliding mode techniques, Control Engineering Practice, vol.10, issue.2, pp.207-217, 1998. ,
DOI : 10.1016/S0967-0661(01)00114-9
Equivalent value filters in disturbance estimation and state observation, Lecture Notes in Control and Information Science, vol.247, pp.167-179, 1999. ,
DOI : 10.1007/BFb0109976
Sliding observer-based feedback control for flexible joints manipulator, Automatica, vol.32, issue.9, pp.1243-1254, 1996. ,
DOI : 10.1016/0005-1098(96)00069-6
Design of observers for linear systems with unknown inputs, IEEE Transactions on Automatic Control, vol.37, issue.6, pp.871-875, 1992. ,
DOI : 10.1109/9.256351
Sliding order and sliding accuracy in sliding mode control, International Journal of Control, vol.51, issue.6, pp.1247-1263, 1993. ,
DOI : 10.1109/TAC.1977.1101661
Robust exact differentiation via sliding mode technique, Automatica, vol.34, issue.3, pp.379-384, 1998. ,
DOI : 10.1016/S0005-1098(97)00209-4
A New Robust Sliding-Mode Observer Design for Monitoring in Chemical Reactors, Journal of Dynamic Systems, Measurement, and Control, vol.126, issue.3, pp.473-478, 2004. ,
DOI : 10.1115/1.1789534
Nonlinear sliding observer based control for a pneumatic robot leg, Int. J. of Robotics and Automation, vol.16, issue.2, pp.100-112, 2001. ,
Sliding Mode Control in Engineering, 2002. ,
DOI : 10.1201/9780203910856
On Sliding Observers for Nonlinear Systems, Journal of Dynamic Systems, Measurement, and Control, vol.109, issue.3, pp.245-252, 1987. ,
DOI : 10.1115/1.3143852
The peaking phenomenon and the global stabilization of nonlinear systems, IEEE Transactions on Automatic Control, vol.36, issue.4, pp.424-440, 1991. ,
DOI : 10.1109/9.75101
An LMI approach for designing sliding mode observers, International Journal of Control, vol.74, issue.16, pp.1559-1568, 2001. ,
DOI : 10.1109/TAC.1971.1099831
Sliding mode observers for robust detection and reconstruction of actuator and sensor faults, International Journal of Robust and Nonlinear Control, vol.29, issue.5, pp.443-463, 2003. ,
DOI : 10.1002/rnc.723
Sliding Modes in Control and Optimization, 1992. ,
DOI : 10.1007/978-3-642-84379-2
Sliding mode control in electromechanical systems, 1999. ,
State observation of nonlinear uncertain dynamical systems, IEEE Transactions on Automatic Control, vol.32, issue.2, pp.88-104, 1987. ,
DOI : 10.1109/TAC.1987.1104530
Sliding mode observer for nonlinear uncertain systems, IEEE Transactions on Automatic Control, vol.46, issue.12, pp.2012-2017, 2001. ,
DOI : 10.1109/9.975511
