MICADO: Models of Interactive Constraints for the Assembling of 1D Deformable Objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
This paper introduces a set of Lagrangian constraints, allowing most needed interaction and combinations of one-dimensional deformable elements for creating complex structures. The proposed tools can potentially be used with a large set of available 1D-models. All constraints formulation are compatible with linear, displacement-based, integration schemes. The proposed constraints allow for real-time complex structure simulation, and also novel interactions between simulated objects. Various examples are provided, illustrating the benefit of the proposed numerical tools.
RR-6573.pdf (551.61 Ko) Télécharger le fichier
inria-00293889 , version 1 (07-07-2008)
  • HAL Id : inria-00293889 , version 1
Adrien Theetten, Laurent Grisoni. MICADO: Models of Interactive Constraints for the Assembling of 1D Deformable Objects. [Research Report] RR-6573, INRIA. 2008, pp.26. ⟨inria-00293889⟩
273 Consultations
151 Téléchargements
