Mean asymptotic behaviour of radix-rational sequences and dilation equations (Extended version) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2008
Philippe Dumas
Connectez-vous pour contacter l'auteur
The generating series of a radix-rational sequence is a rational formal power series from formal language theory viewed through a fixed radix numeration system. For each radix-rational sequence with complex values we provide an asymptotic expansion for the sequence of its Cesàro means. The precision of the asymptotic depends on the joint spectral radius of the linear representation of the sequence, and the coefficients are obtained through some dilation equations. The proofs are based on elementary linear algebra.
Du08.pdf (1.69 Mo) Télécharger le fichier
inria-00294520 , version 1 (09-07-2008)
inria-00294520 , version 2 (21-08-2008)
  • HAL Id : inria-00294520 , version 1
  • ARXIV : 0807.1523
Philippe Dumas. Mean asymptotic behaviour of radix-rational sequences and dilation equations (Extended version). 2008. ⟨inria-00294520v1⟩
89 Consultations
231 Téléchargements
