E. Weinberg and M. Kaazempur-mofrad, On the constitutive models for heart valve leaflet mechanics, Cardiovasc Engng, pp.37-43, 2005.
J. De-hart, F. Baaijens, G. Peters, and P. , A computational fluid-structure interaction analysis of a fiber-reinforced stentless aortic valve, Journal of Biomechanics, vol.36, issue.5, pp.699-712, 2003.
DOI : 10.1016/S0021-9290(02)00448-7
E. Weinberg and M. , Kaazempur-Mofrad, Transient, three-dimensional, multiscale simulations of the human aortic valve, DOI 10, pp.10558-10565, 1007.
B. E. Griffith, R. D. Hornung, D. M. Mcqueen, and C. S. Peskin, An adaptive, formally second order accurate version of the immersed boundary method, Journal of Computational Physics, vol.223, issue.1, pp.10-49, 2007.
DOI : 10.1016/j.jcp.2006.08.019
Z. Jianhai, C. Dapeng, and Z. Shengquan, Ale finite element analysis of the opening and closing process of the artificial mechanical valve, Applied Mathematics and Mechanics, vol.22, issue.1, pp.403-412, 1996.
DOI : 10.1007/BF00131088
Y. Morsi, W. Yang, C. Wong, and S. Das, Transient fluid???structure coupling for simulation of a trileaflet heart valve using weak coupling, Journal of Artificial Organs, vol.18, issue.3, pp.96-103, 2007.
DOI : 10.1007/s10047-006-0365-9
F. Baaijens, A fictitious domain/mortar element method for fluid-structure interaction, International Journal for Numerical Methods in Fluids, vol.79, issue.7, pp.743-761, 2001.
DOI : 10.1002/1097-0363(20010415)35:7<743::AID-FLD109>3.0.CO;2-A
J. De-hart, G. Peters, P. Schreurs, and F. Baaijens, A three-dimensional computational analysis of fluid???structure interaction in the aortic valve, Journal of Biomechanics, vol.36, issue.1, pp.103-112, 2003.
DOI : 10.1016/S0021-9290(02)00244-0
J. Hart, Evaluation of a fictitious domain method for predicting dynamic response of mechanical heart valves, Journal of Fluids and Structures, vol.19, pp.835-850, 2004.
N. M. Diniz-dos-santos, J. Gerbeau, and J. Bourgat, A partitioned fluidstructure algorithm for elastic thin valves with contact, comp, Meth. Appl. Mech. Engng, 2007.
T. A. Laursen, Formulation and treatment of frictional contact problems using finite elements, SUDAM Report, vol.92, issue.6
T. A. Laursen, Computational contact and impact mechanics. Fundamentals of modeling interfacial phenomena in nonlinear finite element analysis, 2002.
T. A. Laursen and J. C. Simo, A continuum-based finite element formulation for the implicit solution of multibody, large deformation-frictional contact problems, International Journal for Numerical Methods in Engineering, vol.44, issue.20, pp.3451-3485, 1993.
DOI : 10.1002/nme.1620362005
M. W. Heinstein, S. W. Attaway, J. W. Swegle, and F. J. Mello, A generalpurpose contact detection algorithm for nonlinear structural analysis code, 1993.
J. O. Hallquist, G. L. Goudreau, and D. J. Benson, Sliding interfaces with contact-impact in large-scale Lagrangian computations, Computer Methods in Applied Mechanics and Engineering, vol.51, issue.1-3, pp.107-13784, 1984.
DOI : 10.1016/0045-7825(85)90030-1
N. Kikuchi and J. T. Oden, Contact problems in elasticity: a study of variational inequalities and finite element methods, SIAM Studies in Applied Mathematics, Society for Industrial and Applied Mathematics (SIAM), vol.8, 1988.
DOI : 10.1137/1.9781611970845
P. Wriggers, Computational Contact Mechanics, 2002.
URL : https://hal.archives-ouvertes.fr/hal-00466790
P. Wriggers, Finite element algorithms for contact problems, Archives of Computational Methods in Engineering, vol.33, issue.4, pp.1-49, 1995.
DOI : 10.1007/BF02736195
A. Klarbring, Large displacement frictional contact: a continuum framework for finite element discretization, European J. Mech. A Solids, vol.14, issue.2, pp.237-253, 1995.
R. Van-loon, P. Anderson, and F. Van-de-vosse, A fluid???structure interaction method with solid-rigid contact for heart valve dynamics, Journal of Computational Physics, vol.217, issue.2, pp.806-823, 2006.
DOI : 10.1016/j.jcp.2006.01.032
C. Carmody, G. Burriesci, I. Howard, and E. Patterson, An approach to the simulation of fluid???structure interaction in the aortic valve, Journal of Biomechanics, vol.39, issue.1, pp.39-158, 2006.
DOI : 10.1016/j.jbiomech.2004.10.038
T. E. Tezduyar and S. Sathe, Modelling of fluid???structure interactions with the space???time finite elements: Solution techniques, International Journal for Numerical Methods in Fluids, vol.195, issue.6-8, pp.855-900, 2007.
DOI : 10.1002/fld.1430
O. Pantz, A frictionless contact algorithm for deformable bodies, ESAIM: Mathematical Modelling and Numerical Analysis, vol.45, issue.2
DOI : 10.1051/m2an/2010041
URL : https://hal.archives-ouvertes.fr/hal-00782884
D. Chapelle and K. Bathe, The Finite Element Analysis of Shells -Fundamentals, 2003.
URL : https://hal.archives-ouvertes.fr/hal-00839738
K. Bathe, Finite Element Procedures, 1996.
J. Gerbeau and M. Vidrascu, A Quasi-Newton Algorithm Based on a Reduced Model for Fluid-Structure Interaction Problems in Blood Flows, ESAIM: Mathematical Modelling and Numerical Analysis, vol.37, issue.4, pp.631-648, 2003.
DOI : 10.1051/m2an:2003049
URL : https://hal.archives-ouvertes.fr/inria-00071895
M. Fernández, J. Gerbeau, and C. Grandmont, A projection semi-implicit scheme for the coupling of an elastic structure with an incompressible fluid, International Journal for Numerical Methods in Engineering, vol.9, issue.4, pp.69-794, 2006.
DOI : 10.1002/nme.1792
M. Fernández and M. Moubachir, A Newton method using exact jacobians for solving fluid???structure coupling, Computers & Structures, vol.83, issue.2-3, pp.127-142, 2005.
DOI : 10.1016/j.compstruc.2004.04.021
S. Badia, F. Nobile, and C. Vergara, Fluid???structure partitioned procedures based on Robin transmission conditions, Journal of Computational Physics, vol.227, issue.14, p.MOX, 2007.
DOI : 10.1016/j.jcp.2008.04.006
R. Torii, M. Oshima, T. Kobayashi, K. Takagi, and T. E. Tezduyar, Computer modeling of cardiovascular fluid???structure interactions with the deforming-spatial-domain/stabilized space???time formulation, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.13-16, pp.70-1885, 2006.
DOI : 10.1016/j.cma.2005.05.050
C. Figueroa, I. Vignon-clementel, K. Jansen, T. Hughes, and C. Taylor, A coupled momentum method for modeling blood flow in three-dimensional deformable arteries, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.41-43, pp.5685-5706, 2006.
DOI : 10.1016/j.cma.2005.11.011
P. Causin, J. Gerbeau, and F. Nobile, Added-mass effect in the design of partitioned algorithms for fluid???structure problems, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.42-44, pp.42-44, 2005.
DOI : 10.1016/j.cma.2004.12.005
URL : https://hal.archives-ouvertes.fr/inria-00071499
C. Förster, W. Wall, and E. Ramm, Artificial added mass instabilities in sequential staggered coupling of nonlinear structures and incompressible viscous flows, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.7, pp.1278-1293, 2006.
DOI : 10.1016/j.cma.2006.09.002
D. Mok, W. Wall, and E. Ramm, Accelerated iterative substructuring schemes for instationary fluid-structure interaction, Computational Fluid and Solid Mechanics, pp.1325-1328, 2001.
DOI : 10.1016/B978-008043944-0/50907-0
N. Santos, Numerical methods for fluid-structure interaction problems with valves
URL : https://hal.archives-ouvertes.fr/tel-00521654
M. Thiriet, Biology and Mechanics of Blood Flows, part II: Mechanics and Medical Aspects of Blood Flows, 2008.
URL : https://hal.archives-ouvertes.fr/hal-00715110
M. Hillairet, Lack of Collision Between Solid Bodies in a 2D Incompressible Viscous Flow, Communications in Partial Differential Equations, vol.336, issue.9
DOI : 10.1142/S0218202506001303
