Chaotic solutions in the quadratic integrate-and-fire neuron with adaptation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Cognitive Neurodynamics Année : 2009
The quadratic integrate-and-fire (QIF) model with adaptation is commonly used as an elementary neuronal model that reproduces the main characteristics of real neurons. In this paper, we introduce a QIF neuron with a nonlinear adaptive current. This model reproduces the neuron-computational features of real neurons and is analytically tractable. It is shown that under a constant current input chaotic firing is possible. In contrast to previous study the neuron is not sinusoidally forced. We show that the spike-triggered adaptation is a key parameter to understand how chaos is generated.
ChaoticQIF.pdf (1.28 Mo) Télécharger le fichier
inria-00300794 , version 1 (20-07-2008)
Gang Zheng, Arnaud Tonnelier. Chaotic solutions in the quadratic integrate-and-fire neuron with adaptation. Cognitive Neurodynamics, 2009, 3 (3), pp.197-204. ⟨10.1007/s11571-008-9069-6⟩. ⟨inria-00300794⟩
251 Consultations
251 Téléchargements
