Detection of Abrupt Changes: Theory and Application, 1993. ,
URL : https://hal.archives-ouvertes.fr/hal-00008518
Non-linear estimation is easy, International Journal of Modelling, Identification and Control, vol.4, issue.1, 2008. ,
DOI : 10.1504/IJMIC.2008.020996
URL : https://hal.archives-ouvertes.fr/inria-00158855
Sira-Ramírez, Closed-loop parametric identification for continuoustime linear systems via new algebraic techniques Continuous-Time Model Identification from Sampled Data, 2008. ,
Efficient algorithms for vectorization and polygonal approximation, 2003. ,
Using penalized contrasts for the change-point problem, Signal Processing, vol.85, issue.8, pp.1501-1510, 2005. ,
DOI : 10.1016/j.sigpro.2005.01.012
URL : https://hal.archives-ouvertes.fr/inria-00070662
A revised look at numerical differentiation with an application to nonlinear feedback control, 2007 Mediterranean Conference on Control & Automation, 2007. ,
DOI : 10.1109/MED.2007.4433728
URL : https://hal.archives-ouvertes.fr/inria-00142588
A delay estimation approach to change-point detection, Proc. 16 th Mediterrean Conf. Control Automation (MED'2007), 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00179775
Optimal vertex adjustement method using Viterbi algorithm for vertex-based shape coding, Electronics Letters, vol.35, 1999. ,
A new algorithm for dominant points detection and polygonization of digital curves, Pattern recognition, 2003. ,
High-Quality Polygonal Contour Approximation Based on Relaxation, International conference on document analysis and recognition, 2001. ,
Optimum Polygonal Approximation of Digitized Curves, Pattern recognition letters, 1994. ,
A New Split-and-merge Technique for Polygonal Approximation of Chain Coded Curves, Pattern recognition letters, 1995. ,
Adding Geometric Constraints to the Vectorization of Line Drawings, Graphics Recognition?Methods and Applications, Lecture Notes and Computer Science, p.1072, 1996. ,
Assessing the behaviour of polygonal approximation algorithms, Pattern recognition, 2004. ,
An Object-Oriented Progressive-Simplification Based Vectorization System for Engineering Drawings: Model, Algorithm, and Performance, IEEE Transactions on Pattern Analysis, issue.8, p.24, 2002. ,
Vectorization in graphics recognition: to thin or not to thin, Proceedings 15th International Conference on Pattern Recognition. ICPR-2000, 2000. ,
DOI : 10.1109/ICPR.2000.906024
URL : https://hal.archives-ouvertes.fr/inria-00099349
Exploring the performance of genetic algorithms as polygonal approximators, Proceedings 15th International Conference on Pattern Recognition. ICPR-2000, 2000. ,
DOI : 10.1109/ICPR.2000.903657
An adaptive method for detecting dominant points, Pattern Recognition, vol.36, issue.10, 2003. ,
DOI : 10.1016/S0031-3203(03)00087-6
Algorithms for straight line fitting using k-means, Pattern Recognition Letters, vol.19, issue.1, 1998. ,
DOI : 10.1016/S0167-8655(97)00154-2
