New algorithms to compute the strength of a graph - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We investigate the problem of computing the strength of a graph. We describe in this article the first polyhedral formulation for the weighted strength in polynomial size of the problem, that is O(mn), where n is the number of vertices and m the number of edges. Moreover, we describe a surprisingly simple FPTAS that gives the strength within 1+epsilon in time O(m log^2(n) log(m/n)/epsilon^2) and space O(m), outperforming by a factor of roughly min(n\sqrt{m},n^5/3) the best known exact algorithm of Trubin associated with the Goldberg and Rao maxflow algorithm for that problem, and of roughly sigma(G) the FPTAS of Plotkin, Shmoys, and Tardos.
RR-6592.pdf (242.62 Ko) Télécharger le fichier
inria-00305560 , version 1 (24-07-2008)
inria-00305560 , version 2 (29-07-2008)
  • HAL Id : inria-00305560 , version 2
Jérôme Galtier. New algorithms to compute the strength of a graph. [Research Report] RR-6592, INRIA. 2008, pp.17. ⟨inria-00305560v2⟩
197 Consultations
183 Téléchargements
