Inverse kinematics using sequential Monte Carlo methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this paper we propose an original approach to solve the Inverse Kinematics problem. Our framework is based on Sequential Monte Carlo Methods and has the advantage to avoid the classical pitfalls of numerical inversion methods since only direct calculations are required. The resulting algorithm accepts arbitrary constraints and exhibits linear complexity with respect to the number of degrees of freedom. Hence, the proposed system is far more efficient for articulated figures with a high number of degrees of freedom
amdo08-final.pdf (2.75 Mo) Télécharger le fichier
Format : Figure, Image
inria-00306599 , version 1 (28-07-2008)
Nicolas Courty, Élise Arnaud. Inverse kinematics using sequential Monte Carlo methods. ADMO 2008 - 5th Conference on Articulated Motion and Deformable Object, Jul 2008, Port d'Andratx, Spain. pp.1-10, ⟨10.1007/978-3-540-70517-8_1⟩. ⟨inria-00306599⟩
210 Consultations
410 Téléchargements
