Tracking articulated bodies using generalized expectation maximization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
A Generalized Expectation Maximization (GEM) algorithm is used to retrieve the pose of a person from a monocular video sequence shot with a moving camera. After embedding the set of possible poses in a low dimensional space using Principal Component Analysis, the configuration that gives the best match to the input image is held as estimate for the current frame. This match is computed iterating GEM to assign edge pixels to the correct body part and to find the body pose that maximizes the likelihood of the assignments.
nordia08-final.pdf (2.93 Mo) Télécharger le fichier
Format : Figure, Image
inria-00306612 , version 1 (03-04-2009)
Andrea Fossati, Élise Arnaud, Radu Horaud, Pascal Fua. Tracking articulated bodies using generalized expectation maximization. NORDIA - CVPRW 2008 - IEEE Computer Society Conference on Computer Vision and Pattern Recognition Workshops, Jun 2008, Anchorage, United States. pp.1-6, ⟨10.1109/CVPRW.2008.4563073⟩. ⟨inria-00306612⟩
180 Consultations
132 Téléchargements
