Energy-delay bounds analysis in wireless multi-hop networks with unreliable radio links - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Energy efficiency and transmission delay are very important parameters for wireless multi-hop networks. Previous works that study energy efficiency and delay are based on the assumption of reliable links. However, the unreliability of the channel is inevitable in wireless multi-hop networks. This paper investigates the trade-off between the energy consumption and the end-to-end delay of multi-hop communications in a wireless network using an unreliable link model. It provides a closed form expression of the lower bound on the energy-delay trade-off for different channel models (AWGN, Raleigh flat fading and Nakagami block-fading) in a linear network. These analytical results are also verified in 2-dimensional Poisson networks using simulations. The main contribution of this work is the use of a probabilistic link model to define the energy efficiency of the system and capture the energy-delay trade-offs. Hence, it provides a more realistic lower bound on both the energy efficiency and the energy-delay trade-off since it does not restrict the study to the set of perfect links as proposed in earlier works.
RR-6598.pdf (610.47 Ko) Télécharger le fichier
inria-00306697 , version 1 (29-07-2008)
  • HAL Id : inria-00306697 , version 1
  • ARXIV : 0807.4656
Ruifeng Zhang, Jean-Marie Gorce, Katia Jaffrès-Runser. Energy-delay bounds analysis in wireless multi-hop networks with unreliable radio links. [Research Report] RR-6598, INRIA. 2008, pp.38. ⟨inria-00306697⟩
136 Consultations
327 Téléchargements
