A Fluid Motion Estimator for Schlieren Image Velocimetry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
In this paper, we address the problem of estimating the motion of fluid flows that are visualized through a Schlieren system. Such a system is well known in fluid mechanics as it enables the visualization of unseeded flows. As the resulting images exhibit very low photometric contrasts, classical motion estimation methods based on the brightness consistency assumption (correlation-based approaches, optical flow methods) are completely inefficient. This work aims at proposing a sound energy based estimator dedicated to these particular images. The energy function to be minimized is composed of (a) a novel data term describing the fact that the observed luminance is linked to the gradient of the fluid density and (b) a specific div curl regularization term. The relevance of our estimator is demonstrated on real-world sequences.
Eccv06Arnaud.pdf (1.22 Mo) Télécharger le fichier
Format : Figure, Image
inria-00590206 , version 1 (03-04-2009)
inria-00590206 , version 2 (03-05-2011)
Élise Arnaud, Etienne Mémin, Roberto Sosa, Guillermo Artana. A Fluid Motion Estimator for Schlieren Image Velocimetry. 9th European Conference on Computer Vision (ECCV '06), May 2006, Graz, Austria. pp.198--210, ⟨10.1007/11744023_16⟩. ⟨inria-00590206v2⟩
433 Consultations
486 Téléchargements
