Reports
An Automated Process for Designing UML Profiles
Abstract : Building a UML profile may be a tedious and error-prone process. There is no precise methodology to guide the process or to verify that all concepts have been implemented once and only once. Best practices recommend starting by gathering concepts in a technology-independent domain view before implementation. Still, the adequation between the domain view and the implementation should be verified. This paper proposes an automatic process to transform a domain model into a profile-based implementation. To reduce "accidental complexity" in the domain model and fully benefit from advanced profiling features in the generated profile, our process uses the "multi-level paradigm" and its "deep characterization" mechanisms. The value of this paradigm for the definition of UML profiles is assessed and applied to the subset of a recently adopted OMG UML Profile, an excerpt of the MARTE time profile. As a by-product, our process involves an inexpensive profile-based implementation of the multi-level paradigm within UML2 tools.
Document type :
Reports
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/inria-00308386
Contributor : Frédéric Mallet Connect in order to contact the contributor
Submitted on : Wednesday, July 30, 2008 - 11:00:01 AM
Last modification on : Saturday, June 25, 2022 - 10:59:33 PM
Long-term archiving on: : Saturday, November 26, 2016 - 1:05:57 AM
File
RR-6599.pdf
Identifiers
  • HAL Id : inria-00308386, version 1
Collections
Citation
François Lagarde, Frédéric Mallet, Charles André, Sébastien Gérard, François Terrier. An Automated Process for Designing UML Profiles. [Research Report] RR-6599, INRIA. 2008. ⟨inria-00308386⟩
Share
Metrics
Record views
297
Files downloads
103
