Analysis of EEG records in an epileptic patient using wavelet transform, Journal of Neuroscience Methods, vol.123, issue.1, pp.821-826, 2004. ,
DOI : 10.1016/S0165-0270(02)00340-0
Nikiforov, «Detection of Abrupt Changes: Theory and Application», 1993. ,
Fellow , IEEE, «On Instantaneous Amplitude and Phase of Signals», IEEE Transactions on signal processing, vol.45, issue.3, 1997. ,
«Non-parametric statistical diagnosis: Problems and Methods», 2000. ,
DOI : 10.1007/978-94-015-9530-8
«A Field Guide to Algebra», 2005. ,
Horváth, «Limit Theorems in Change-Point Analysis», 1997. ,
Correcteurs proportionnels-int??graux g??n??ralis??s, ESAIM: Control, Optimisation and Calculus of Variations, vol.7, pp.23-41, 2002. ,
DOI : 10.1051/cocv:2002002
An algebraic framework for linear identification, ESAIM: Control, Optimisation and Calculus of Variations, vol.9, pp.151-168, 2003. ,
DOI : 10.1051/cocv:2003008
Sira-Ramírez, «Questioning some paradigms of signal processing via concrete examples», Algebraic Methods in Flatness, Signal Processing and State Estimation, Editiorial Lagares, pp.1-21, 2003. ,
Compression diff??rentielle de transitoires bruit??s, Comptes Rendus Mathematique, vol.339, issue.11, pp.821-826, 2004. ,
DOI : 10.1016/j.crma.2004.10.003
Sira-Ramírez, «Une autre vision de l'identification de signaux et systèmes», 2004. ,
Sira-Ramírez, «Analyse et représentation de signaux transitoires: application à la compression, au débruitage et à la détection de ruptures», Actes 20 e Coll. GRETSI, Louvain-la-Neuve, 2005. ,
Analyse non standard du bruit, «Analyse non standard du bruit», pp.797-802, 2006. ,
DOI : 10.1016/j.crma.2006.02.037
URL : https://hal.archives-ouvertes.fr/inria-00001134
Sira-Ramírez, «Non-linear estimation is easy», Int. J. Modelling Identification Control ,
DOI : 10.1504/ijmic.2008.020996
URL : http://arxiv.org/abs/0710.4486
Automated seizure detection using a self-organizing neural network, Electroencephalography and Clinical Neurophysiology, vol.99, issue.3, pp.257-266, 1996. ,
DOI : 10.1016/0013-4694(96)96001-0
«Detecting epileptic seizure activity in the EEG by Independent Component Analysis», 2003. ,
A Novel Constrained Topographic Independent Component Analysis for Separation of Epileptic Seizure Signals, Computational Intelligence and Neuroscience, vol.2007, p.21315, 2007. ,
DOI : 10.1016/S1388-2457(99)00039-5
«Parameter estimation via differentiel algebra and operationnel calculus», preprint submitted to Signal Processing ,
«New algebraic estimation techniques in signal processing and control». In Fast Estimation and Identification Methods in Control and Signal Processing, 2006. ,
«A revised look at numerical differentiation with an application to nonlinear feed back control», Proceeding of the 15th Mediterranean Conferance on Control and Automation, 2007. ,
«A delay estimation aproach to change-point detection» ,
Epileptic transient detection: wavelets and time-frequency approaches, Neurophysiologie Clinique/Clinical Neurophysiology, vol.32, issue.3, pp.175-92, 2002. ,
DOI : 10.1016/S0987-7053(02)00304-0
URL : https://hal.archives-ouvertes.fr/inserm-00130050
Le sommeil normal et pathologique: troubles du sommeil et de l'eveil, pp.133-141, 1998. ,
Bremmer, «Operational Calculus Based on the Two-Sided Laplace Integral», 1955. ,
«Fourier and wavelet analyses of normal and epileptic electroencephalogram (EEG)», Neural Engineering, Conference Proceedings, First International IEEE EMBS Conference, pp.406-409, 2003. ,
A Real-Time QRS Detection Algorithm, IEEE Transactions on Biomedical Engineering, vol.32, issue.3, pp.230-236, 1985. ,
DOI : 10.1109/TBME.1985.325532
«Wavelet based analysis and characterization of ECG signal», J. Eng. Technol, vol.28, issue.2, pp.47-55, 2004. ,
«MIT-BIH arrythmia database directory», Massachusetts Institute of Technology, 1988. ,
«A noise stress test for arrythmia detectors», Compt. Cardio, vol.11, pp.381-384, 1984. ,
