New interface
Reports (Research report)
multiobjective optimization in hydrodynamic stability control
Abstract : We focus on a shape optimization problem in hydrodynamic stability control. The goal is to minimize the drag in a flow regime by modification of the underlying geometry while ensuring hydrodynamic stability. We propose an extension of a numerical scheme to speed up the computations and avoid the solving of the original PDE model. Therefore, a metamodel is used as approximation of the original model. A Particle Swarm Optimization algorithm is used in conjunction with a Nash game to consider both objectives simultaneously, with a split of design variables established from a sensitivity analysis accounting for first and second derivatives of functionals related to the metamodel.
Document type :
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00309693
Contributor : Régis Duvigneau Connect in order to contact the contributor
Submitted on : Thursday, August 7, 2008 - 11:46:40 AM
Last modification on : Wednesday, October 26, 2022 - 8:16:16 AM
Long-term archiving on: : Thursday, June 3, 2010 - 6:01:36 PM
RR-6608.pdf
Identifiers
  • HAL Id : inria-00309693, version 1
Citation
Frank Strauss, Jean-Antoine Desideri, Régis Duvigneau, Vincent Heuveline. multiobjective optimization in hydrodynamic stability control. [Research Report] RR-6608, INRIA. 2008. ⟨inria-00309693⟩
Share
Metrics
Record views
142
Files downloads
107
