Using Branch-and-Price-and-Cut to Solve Origin-Destination Integer Multicommodity Flow Problems, Operations Research, vol.48, issue.2, pp.318-326, 2000. ,
DOI : 10.1287/opre.48.2.318.12378
Branch-and-Price: Column Generation for Solving Huge Integer Programs, Operations Research, vol.46, issue.3, pp.316-329, 1998. ,
DOI : 10.1287/opre.46.3.316
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.197.7390
A Node-Flow Model for the 1D Stock Cutting: Robust Branch-Cut-and-Price, Tech. report RPEP, vol.5, issue.7, 2005. ,
Comparison of bundle and classical column generation, Mathematical Programming, vol.94, issue.1, pp.299-344, 2008. ,
DOI : 10.1007/s10107-006-0079-z
URL : https://hal.archives-ouvertes.fr/inria-00070554
Génération de Colonnes et de Coupes utilisant des sous-problèmes de plus court chemin, Thèse de doctorat, 2003. ,
Carath??odory bounds for integer cones, Operations Research Letters, vol.34, issue.5, pp.564-568, 2006. ,
DOI : 10.1016/j.orl.2005.09.008
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.93.1908
Vehicle Routing with Time Windows and Split Deliveries, 2005. ,
Lagrangian Relaxation for Integer Programming, Math. Prog. St, vol.2, pp.82-114, 1974. ,
DOI : 10.1007/978-3-540-68279-0_9
Computing Partitions with Applications to the Knapsack Problem, Journal of the ACM, vol.21, issue.2, pp.277-292, 1974. ,
DOI : 10.1145/321812.321823
Branch, Cut, and Price: Sequential and Parallel, pp.223-269, 1998. ,
DOI : 10.1007/3-540-45586-8_6
A column generation algorithm for bandwidth packing, Telecommunication Systems, vol.33, issue.1, pp.185-195, 1994. ,
DOI : 10.1007/BF02109857
From High-Level Model to Branch-and-Price Solution in G12 The Fifth International Conference on Integration of AI and OR Techniques in Constraint Programming for Combinatorial Optimization Problems, LNCS, vol.5015, pp.218-232, 2008. ,
An integer programming approach to scheduling, Computer Scheduling of Public Transport Urban Passenger Vehicle and Crew Scheduling, pp.269-280, 1981. ,
Functional description of MINTO, a Mixed INTeger Optimizer, 1993. ,
Exact solution of bin packing problems using column generation and branch-and-bound, Annals of Operations Research, vol.86, pp.629-659, 1999. ,
DOI : 10.1023/A:1018952112615
Branch-and-Price Algorithms for the One-Dimensional Cutting Stock Problem, Computational Optimization and Applications, vol.9, issue.3, pp.211-228, 1998. ,
DOI : 10.1023/A:1018346107246
Computational study of a column generation algorithm for bin packing and cutting stock problems, Mathematical Programming, vol.86, issue.3, pp.565-594, 1999. ,
DOI : 10.1007/s101070050105
On Dantzig-Wolfe Decomposition in Integer Programming and ways to Perform Branching in a Branch-and-Price Algorithm, Operations Research, vol.48, issue.1, pp.111-128, 2000. ,
DOI : 10.1287/opre.48.1.111.12453
URL : https://hal.archives-ouvertes.fr/inria-00342641
Exact Algorithm for Minimising the Number of Setups in the One-Dimensional Cutting Stock Problem, Operations Research, vol.48, issue.6, pp.915-926, 2000. ,
DOI : 10.1287/opre.48.6.915.12391
URL : https://hal.archives-ouvertes.fr/inria-00342639
Extending Dantzig's bound to the bounded multiple-class binary Knapsack problem, Mathematical Programming, vol.94, issue.1, pp.125-136, 2002. ,
DOI : 10.1007/s10107-002-0300-7
Implementing Mixed Integer Column Generation Column Generation, Kluwer. [24] F. Vanderbeck. BaPCod - A generic Branch-And-Price Code, 2005. ,
A generic view of Dantzig???Wolfe decomposition in mixed integer programming, Operations Research Letters, vol.34, issue.3, pp.296-306, 2006. ,
DOI : 10.1016/j.orl.2005.05.009
URL : https://hal.archives-ouvertes.fr/inria-00342623
On Compact Formulations for Integer Programs Solved by Column Generation, Annals of Operations Research, vol.165, issue.1, pp.375-388, 2005. ,
DOI : 10.1007/s10479-005-3455-9
User guide and Reference Manual, 2007. ,
