The load rebalancing problem, Proceedings of the Fifteenth Annual ACM Symposium on Parallel Algorithms and Architectures, pp.258-265, 2003. ,
An Experimental Study of Data Migration Algorithms, Proceedings of the 5th International Workshop on Algorithm Engineering, p.145, 2001. ,
DOI : 10.1007/3-540-44688-5_12
Digraphs?Theory, algorithms and applications, 2002. ,
A Branch-and-Bound procedure to minimize total tardiness on one machine with arbitrary release dates, European Journal of Operational Research, vol.158, issue.3 ,
DOI : 10.1016/S0377-2217(03)00378-3
URL : https://hal.archives-ouvertes.fr/hal-00357955
Dynamic programming, 1957. ,
Leprobì eme de l'ordonnancement des paiements de dettes, RAIRO?Operations Research, vol.18, issue.1, 1984. ,
DOI : 10.1051/ro/1984180100431
URL : http://archive.numdam.org/article/RO_1984__18_1_43_0.pdf
Probì emes d'ordonnancementàordonnancement`ordonnancementà contraintes de ressources : algorithmes et complexité, of Méthodologie & Architecture des Systèmes Informatiques. Université P. et M. Curie et CNRS, 1984. ,
Probì emes d'ordonnancements : modélisation, complexité et algorithmes, Etudes et Recherches en Informatique. Masson, 1988. ,
Scheduling file transfers in a distributed network, Proceedings of the second annual ACM symposium on Principles of distributed computing , PODC '83, pp.254-266, 1983. ,
DOI : 10.1145/800221.806726
Scheduling File Transfers, SIAM Journal on Computing, vol.14, issue.3, 1985. ,
DOI : 10.1137/0214054
On an approximation measure founded on the links between optimization and polynomial approximation theory, Theoretical Computer Science, vol.158, issue.1-2, pp.117-141, 1996. ,
DOI : 10.1016/0304-3975(95)00060-7
Computers and intractability?A guide to the theory of N P -completeness, 1979. ,
Dynamic file migration in distributed computer systems, Communications of the ACM, vol.33, issue.2, pp.177-189, 1990. ,
DOI : 10.1145/75577.75583
On algorithms for efficient data migration, Proceedings of the 12th Annual ACM-SIAM Symposium on Discrete Algorithms, pp.620-629, 2001. ,
The Power of Dominance Relations in Branch-and-Bound Algorithms, Journal of the ACM, vol.24, issue.2, pp.264-279, 1977. ,
DOI : 10.1145/322003.322010
Improved dynamic programming in connection with an FPTAS for the knaspack problem, Journal of Combinatorial Optimization, vol.3, issue.1, pp.59-71, 1999. ,
DOI : 10.1023/A:1009813105532
Knapsack problems, 2004. ,
DOI : 10.1007/978-3-540-24777-7
Sorting and searching, volume 3 of The Art of Computer Programming, 1998. ,
Where are the hard knapsack problems? Computers & Operations Research, pp.2271-2284, 2005. ,
Data migration with edge capacities and machine speeds, 2001. ,
Approximate resolution of a resourceconstrained scheduling problem, Nortel GSM Access R&D, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00445528
A practical approach to combinatorial optimization problems encountered in the design of a high availability distributed system, Proceedings of INOC, pp.532-539, 2003. ,
