Sébastien Boyaval, Claude Le Bris, Yvon Maday, Ngoc Cuong Nguyen, Anthony Patera. A Reduced Basis Approach for Variational Problems with Stochastic Parameters: Application to Heat Conduction with Variable Robin Coefficient. [Research Report] RR-6617, INRIA. 2008, pp.50.
⟨inria-00311463⟩
