Automatic choice of global shape functions in structural analysis, AIAA Journal, vol.16, issue.5, pp.525-528, 1978. ,
DOI : 10.2514/3.7539
A Stochastic Collocation Method for Elliptic Partial Differential Equations with Random Input Data, SIAM Journal on Numerical Analysis, vol.45, issue.3, pp.1005-1034, 2007. ,
DOI : 10.1137/050645142
Solving elliptic boundary value problems with uncertain coefficients by the finite element method: the stochastic formulation, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.12-16, pp.1251-1294, 2005. ,
DOI : 10.1016/j.cma.2004.02.026
An ???empirical interpolation??? method: application to efficient reduced-basis discretization of partial differential equations, Comptes Rendus Mathematique, vol.339, issue.9, pp.667-672, 2004. ,
DOI : 10.1016/j.crma.2004.08.006
URL : https://hal.archives-ouvertes.fr/hal-00021702
Une variante de la th??orie de l'homog??n??isation stochastique des op??rateurs elliptiques, Comptes Rendus Mathematique, vol.343, issue.11-12, pp.11-12717, 2006. ,
DOI : 10.1016/j.crma.2006.09.034
Reduced-Basis Approach for Homogenization beyond the Periodic Setting, Multiscale Modeling & Simulation, vol.7, issue.1, pp.466-494, 2008. ,
DOI : 10.1137/070688791
URL : https://hal.archives-ouvertes.fr/inria-00132763
A monotonic evaluation of lower bounds for inf-sup stability constants in the frame of reduced basis approximations, Comptes Rendus Mathematique, vol.346, issue.23-24, 2008. ,
DOI : 10.1016/j.crma.2008.10.012
URL : https://hal.archives-ouvertes.fr/hal-00873076
Stochastic Finite Element Modelling of Fibre-Metal Laminates, 45th AIAA/ASME/ASCE/AHS/ASC Structures, Structural Dynamics & Materials Conference, 2004. ,
DOI : 10.2514/6.2004-1992
URL : https://hal.archives-ouvertes.fr/hal-00507457
Solution of stochastic partial differential equations using Galerkin finite element techniques, Computer Methods in Applied Mechanics and Engineering, vol.190, issue.48, pp.6359-6372, 2001. ,
DOI : 10.1016/S0045-7825(01)00237-7
Numerical challenges in the use of polynomial chaos representations for stochastic processes, SIAM on Journal on Scientific Computing, vol.26, issue.2, pp.698-719, 2004. ,
On the Error Behavior of the Reduced Basis Technique for Nonlinear Finite Element Approximations, ZAMM - Zeitschrift f??r Angewandte Mathematik und Mechanik, vol.18, issue.4, pp.21-28, 1983. ,
DOI : 10.1002/zamm.19830630105
Finite elements for elliptic problems with stochastic coefficients, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.2-5, pp.205-228, 2005. ,
DOI : 10.1016/j.cma.2004.04.008
Stochastic finite element analysis for multiphase flow in heterogeneous porous media, Tranp. Porous Media, vol.32, issue.239, 1998. ,
Stochastic finite elements: A spectral approach, 1991. ,
DOI : 10.1007/978-1-4612-3094-6
Efficient reduced-basis treatment of nonaffine and nonlinear partial differential equations, M2AN), pp.575-605, 2007. ,
DOI : 10.1051/m2an:2007031
URL : https://hal.archives-ouvertes.fr/hal-00112154
A successive constraint linear optimization method for lower bounds of parametric coercivity and inf???sup stability constants, Comptes Rendus Mathematique, vol.345, issue.8, pp.473-478, 2007. ,
DOI : 10.1016/j.crma.2007.09.019
A Heat Transfer Textbook, 2002. ,
Spectral stochastic homogenization of divergence-type PDEs, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.6-8, pp.429-447, 2004. ,
DOI : 10.1016/j.cma.2003.05.001
Hierarchical parallelisation for the solution of stochastic finite element equations, Computers & Structures, vol.83, issue.14, pp.1033-1047, 2005. ,
DOI : 10.1016/j.compstruc.2004.11.014
Probability Theory, volume I-II, 1978. ,
Output bounds for reduced-basis approximations of symmetric positive definite eigenvalue problems, Comptes Rendus de l'Acad??mie des Sciences - Series I - Mathematics, vol.331, issue.2, pp.153-158, 2000. ,
DOI : 10.1016/S0764-4442(00)00270-6
Stochastic approaches to uncertainty quantification in CFD simulations, Numerical Algorithms, vol.187, issue.2, pp.209-236, 2005. ,
DOI : 10.1007/BF02810624
Galerkin methods for linear and nonlinear elliptic stochastic partial differential equations, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.12-16, pp.1295-1331, 2005. ,
DOI : 10.1016/j.cma.2004.05.027
Stochastic Reduced Basis Methods, AIAA Journal, vol.40, issue.8, pp.1653-1664, 2002. ,
DOI : 10.2514/2.1837
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.7.1155
Certified real-time solution of parametrized partial differential equations, Handbook of Materials Modeling, pp.1523-1558, 2005. ,
A Sparse Grid Stochastic Collocation Method for Partial Differential Equations with Random Input Data, SIAM Journal on Numerical Analysis, vol.46, issue.5, pp.2309-2345, 2008. ,
DOI : 10.1137/060663660
Reduced basis technique for nonlinear analysis of structures, 20th Structures, Structural Dynamics, and Materials Conference, pp.455-462, 1980. ,
DOI : 10.2514/6.1979-747
Estimation of the error in the reduced basis method solution of nonlinear equations, Mathematics of Computation, vol.45, issue.172, pp.487-496, 1985. ,
DOI : 10.1090/S0025-5718-1985-0804937-0
Reliable real-time solution of parametrized partial differential equations: Reducedbasis output bounds methods, Journal of Fluids Engineering, vol.124, issue.1, pp.70-80, 2002. ,
Reduced basis approximation and a posteriori error estimation for affinely parametrized elliptic coercive partial differential equations; Application to transport and continuum mechanics, Arch Comput Methods Eng, pp.10-1007, 2008. ,
Hybridization of stochastic reduced basis methods with polynomial chaos expansions, Probabilistic Engineering Mechanics, vol.21, issue.2, pp.182-192, 2006. ,
DOI : 10.1016/j.probengmech.2005.09.003
Karhunen???Lo??ve approximation of random fields by generalized fast multipole methods, Journal of Computational Physics, vol.217, issue.1, pp.100-122, 2006. ,
DOI : 10.1016/j.jcp.2006.01.048
A stochastic finite element procedure for moment and reliability analysis, Revue europ??enne de m??canique num??rique, vol.15, issue.7-8, pp.825-866, 2006. ,
DOI : 10.3166/remn.15.825-866
Convergence rates for sparse chaos approximations of elliptic problems with stochastic coefficients, IMA Journal of Numerical Analysis, vol.27, issue.2, pp.232-261, 2007. ,
DOI : 10.1093/imanum/drl025
Quasi-Monte Carlo algorithms for diffusion equations in high dimensions, Mathematics and Computers in Simulation, vol.68, issue.1, pp.23-41, 2005. ,
DOI : 10.1016/j.matcom.2004.09.003
An adaptive multi-element generalized polynomial chaos method for stochastic differential equations, Journal of Computational Physics, vol.209, issue.2, pp.617-642, 2005. ,
DOI : 10.1016/j.jcp.2005.03.023
URL : http://www.dtic.mil/get-tr-doc/pdf?AD=ADA458984
Error control in multi-element generalized polynomial chaos method for elliptic problems with random coefficients Available online 1, Communications in Computational Physics, vol.5, issue.24, pp.793-820, 2008. ,
The Homogeneous Chaos, American Journal of Mathematics, vol.60, issue.4, pp.897-936, 1938. ,
DOI : 10.2307/2371268
The Wiener--Askey Polynomial Chaos for Stochastic Differential Equations, SIAM Journal on Scientific Computing, vol.24, issue.2, pp.619-644, 2002. ,
DOI : 10.1137/S1064827501387826
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-l` es-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche, 2004. ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
