The load rebalancing problem, Proceedings of the Fifteenth Annual ACM Symposium on Parallel Algorithms and Architectures, pp.258-265, 2003. ,
An Experimental Study of Data Migration Algorithms, Proceedings of the 5th International Workshop on Algorithm Engineering, p.145, 2001. ,
DOI : 10.1007/3-540-44688-5_12
Leprobì eme de l'ordonnancement des paiements de dettes, RAIRO?Operations Research, vol.18, 1984. ,
DOI : 10.1051/ro/1984180100431
URL : http://archive.numdam.org/article/RO_1984__18_1_43_0.pdf
Algorithmic Aspects of Using Small Instance Relaxations in Parallel Branch-and-Cut, Algorithmica, vol.30, issue.4, 1998. ,
DOI : 10.1007/s00453-001-0029-3
Scheduling file transfers in a distributed network, Proceedings of the second annual ACM symposium on Principles of distributed computing , PODC '83, pp.254-266, 1983. ,
DOI : 10.1145/800221.806726
Scheduling File Transfers, SIAM Journal on Computing, vol.14, issue.3, 1985. ,
DOI : 10.1137/0214054
On an approximation measure founded on the links between optimization and polynomial approximation theory, Theoretical Computer Science, vol.158, issue.1-2, pp.117-141, 1996. ,
DOI : 10.1016/0304-3975(95)00060-7
Induced binary probabilities and the linear ordering polytope: a status report, Mathematical Social Sciences, vol.23, issue.1, pp.67-80, 1992. ,
DOI : 10.1016/0165-4896(92)90038-7
Computers and intractability?A guide to the theory of N P -completeness, 1979. ,
A Cutting Plane Algorithm for the Linear Ordering Problem, Operations Research, vol.32, issue.6, pp.1195-1220, 1984. ,
DOI : 10.1287/opre.32.6.1195
Facets of the linear ordering polytope, Mathematical Programming, pp.43-60, 1985. ,
DOI : 10.1007/BF01582010
On the acyclic subgraph polytope, Mathematical Programming, pp.28-42, 1985. ,
DOI : 10.1007/BF01582009
Geometric algorithms and combinatorial optimization, Algorithms and Combinatorics, vol.2, 1988. ,
On algorithms for efficient data migration, Proceedings of the 12th Annual ACM- SIAM Symposium on Discrete Algorithms, pp.620-629, 2001. ,
Fault tolerance in distributed systems. Distributed Systems, 1994. ,
Knapsack problems, 2004. ,
DOI : 10.1007/978-3-540-24777-7
Polyhedral combinatorics of a resourceconstrained ordering problem part II: on the process move program polytope, 2006. ,
Solving Linear Ordering Problems with a Combined Interior Point/Simplex Cutting Plane Algorithm, High performance optimization, pp.349-366, 2000. ,
DOI : 10.1007/978-1-4757-3216-0_14
Polyhedral approaches to machine scheduling, 1994. ,
The linear ordering problem: algorithms and applications, volume 8 of Research and exposition in mathematics, 1985. ,
Data migration with edge capacities and machine speeds, 2001. ,
On a resource-constrained scheduling problem with application to distributed systems reconfiguration, European Journal of Operational Research, vol.183, issue.2, pp.546-563, 2007. ,
DOI : 10.1016/j.ejor.2006.10.011
URL : https://hal.archives-ouvertes.fr/inria-00311377
Approximate resolution of a resourceconstrained scheduling problem, Journal of Heuristics, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00445528
A fast heuristic for a resource-constrained scheduling problem, 2005. ,
Polyhedral combinatorics of a resourceconstrained ordering problem part I: on the partial linear ordering polytope, 2006. ,
A practical approach to combinatorial optimization problems encountered in the design of a high availability distributed system, Proceedings of the International Network Optimization Conference, pp.532-539, 2003. ,
