Monitoring Information flow by Diagnosis Techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
In this paper, we are interested in constructing monitors for the detection of confidential information flow in the context of partially observable discrete event systems. We focus on the case where the secret information is given as a regular language. We first characterize the set of observations allowing an attacker to infer the secret behaviors. We consider the general case where the attacker and the administrator have different partial views of the system. Further, based on the diagnosis of discrete event systems, we provide necessary and sufficient conditions under which detection and prediction of secret information flow can be ensured and a construction of a monitor ensuring this task.
PI-1901.pdf (335.31 Ko) Télécharger le fichier
inria-00312747 , version 1 (26-08-2008)
inria-00312747 , version 2 (26-08-2008)
  • HAL Id : inria-00312747 , version 1
Jérémy Dubreil, Thierry Jéron, Hervé Marchand. Monitoring Information flow by Diagnosis Techniques. [Research Report] PI 1901, 2008, pp.15. ⟨inria-00312747v1⟩
84 Consultations
28 Téléchargements
