Conflict Ontology Enrichment Based on Triggers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Chahnaz Zakaria
  • Fonction : Auteur
  • PersonId : 852993
Olivier Curé
Kamel Smaïli
In this paper, we propose an ontology-based approach that enables to detect the emergence of relational conflicts between persons that cooperate on computer supported projects. In order to detect these conflicts, we analyze, using this ontology, the e-mails exchanged between these people. Our method aims to inform project team leaders of such situation hence to help them in preventing serious disagreement between involved employees. The approach we present builds a domain ontology of relational conflicts in two phases. First we conceptualize the domain by hand, then we enrich the ontology by using the trigger model that enables to find out terms in corpora which correspond to different conflicts.
onisw11-zakaria.pdf (94.81 Ko) Télécharger le fichier
inria-00315300 , version 1 (28-02-2009)
  • HAL Id : inria-00315300 , version 1
Chahnaz Zakaria, Olivier Curé, Kamel Smaïli. Conflict Ontology Enrichment Based on Triggers. The 2nd International workshop on Ontologies and Information Systems for the Semantic Web, ACM 17th Conference on Information and Knowledge Management, Oct 2008, Napa Valley, California, United States. ⟨inria-00315300⟩
159 Consultations
212 Téléchargements
