Network Reconfiguration using Cops-and-Robber Games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
The process number is the number of requests that have to be simultaneously disturbed during a routing reconfiguration phase of a connection oriented network. From a graph theory point of view, it is similar to the pathwidth. However they are not always equal in general graphs. Determining these parameters is in general NP-complete. In this paper, we propose a polynomial algorithm to compute an approximation of the process number of digraphs, improving the efficiency of the previous exponential algorithm.
RR-6694.pdf (359.39 Ko) Télécharger le fichier
inria-00315568 , version 1 (28-08-2008)
inria-00315568 , version 2 (26-09-2008)
inria-00315568 , version 3 (16-10-2008)
  • HAL Id : inria-00315568 , version 3
David Coudert, Dorian Mazauric. Network Reconfiguration using Cops-and-Robber Games. [Research Report] RR-6694, INRIA. 2008. ⟨inria-00315568v3⟩
117 Consultations
160 Téléchargements
