HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
A Time-Consistent Video Segmentation Algorithm for Real-Time Implementation
Abstract : In this paper, we propose a time consistent video segmentation algorithm designed for real-time implementation. Our algorithm is based on a region merging process that combines both spatial and motion information. The spatial segmentation takes benefit of an adaptive decision rule and a specific order of merging. Our method has proven to be efficient for the segmentation of natural images with few parameters to be set. Temporal consistency of the segmentation is ensured by incorporating motion information through the use of an improved change detection mask. This mask is designed using both illumination differences between frames, and region segmentation of the previous frame. By considering both pixel and region levels, we obtain a particularly efficient algorithm at a low computational cost, allowing its implementation in real-time on the TriMedia processor for CIF image sequences.
Complete list of metadata
Cited literature [30 references]  Display  Hide  Download
https://hal.inria.fr/inria-00315959
Contributor : David Tschumperlé Connect in order to contact the contributor
Submitted on : Tuesday, September 2, 2008 - 9:16:09 AM
Last modification on : Friday, February 25, 2022 - 4:48:02 PM
Long-term archiving on: : Thursday, June 3, 2010 - 5:31:34 PM
File
VLSI_final_08.pdf
Identifiers
Citation
Mohammed Elhassani, Stéphanie Jehan-Besson, Luc Brun, Marinette Revenu, Marc Duranton, et al.. A Time-Consistent Video Segmentation Algorithm for Real-Time Implementation. VLSI Design, Hindawi Publishing Corporation, 2008, 11 pp. ⟨10.1155/2008/892370⟩. ⟨inria-00315959⟩
Share
Metrics
Record views
119
Files downloads
101
