Interference Modeling in CSMA Multi-Hop Wireless Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Anthony Busson
Guillaume Chelius
  • Fonction : Auteur
  • PersonId : 853112
Jean-Marie Gorce
In analytical studies of multi-hop wireless networks, the spatial distribution of transmitters is typically modeled using a homogeneous Poisson point process. In this report, we show why such a modeling is inaccurate and leads to an inappropriate interference distribution in the case of CSMA/CA networks. We then study a more realistic model, the Matèrn point process, which still reveals some unexpected flaws such as an under-estimation of the transmitters density. To get round these limitations, we propose the use of an alternate model, referred to as the \emph{Simple Sequential Inhibition} (SSI) point process, which we assert being a valuable and more appropriate model for CSMA/CA networks. We present some analytical results on the Matèrn and the SSI model and study by simulation the interference distribution resulting from the different point processes.
rr-main.pdf (1.02 Mo) Télécharger le fichier
inria-00316029 , version 1 (02-09-2008)
inria-00316029 , version 2 (11-09-2008)
inria-00316029 , version 3 (11-02-2009)
  • HAL Id : inria-00316029 , version 3
Anthony Busson, Guillaume Chelius, Jean-Marie Gorce. Interference Modeling in CSMA Multi-Hop Wireless Networks. [Research Report] RR-6624, INRIA. 2009, pp.21. ⟨inria-00316029v3⟩
475 Consultations
612 Téléchargements
