Smoothed extreme value estimators of non-uniform point processes boundaries with application to star-shaped supports estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Statistics - Theory and Methods Année : 2008
We address the problem of estimating the edge of a bounded set in $\Mathbb{R}^d$ given a random set of points drawn from the interior. Our method is based on a transformation of estimators dedicated to uniform point processes and obtained by smoothing some of its bias corrected extreme points. An application to the estimation of star-shaped supports is presented.
inria-00317239 , version 1 (03-09-2008)
Stéphane Girard, Ludovic Menneteau. Smoothed extreme value estimators of non-uniform point processes boundaries with application to star-shaped supports estimation. Communications in Statistics - Theory and Methods, 2008, 37 (6), pp.881-897. ⟨10.1080/03610920701693884⟩. ⟨inria-00317239⟩
143 Consultations
0 Téléchargements
