Optimal Control of the Atmospheric Reentry of a Space Shuttle by an Homotopy Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Optimal Control Applications and Methods Année : 2011
This paper deals with the optimal control problem of the atmospheric reentry of a space shuttle with a second-order state constraint on the thermal flux. We solve the problem using the shooting algorithm combined with an homotopy method which automatically determines the structure of the optimal trajectory (composed of one boundary arc and one touch point).
RR-6627.pdf (460.6 Ko) Télécharger le fichier
inria-00317722 , version 1 (03-09-2008)
Audrey Hermant. Optimal Control of the Atmospheric Reentry of a Space Shuttle by an Homotopy Method. Optimal Control Applications and Methods, 2011, 32 (6), pp.627-646. ⟨10.1002/oca.961⟩. ⟨inria-00317722⟩
313 Consultations
655 Téléchargements
