Error recovery for variable length codes, IEEE Transactions on Information Theory, vol.31, issue.6, pp.794-801, 1985. ,
DOI : 10.1109/TIT.1985.1057110
More on the error recovery for variable-length codes, IEEE Transactions on Information Theory, vol.41, issue.6, pp.2064-2071, 1995. ,
DOI : 10.1109/18.476338
Synchronization recovery of variable-length codes, IEEE Transactions on Information Theory, vol.48, issue.1, pp.219-227, 2002. ,
DOI : 10.1109/18.971750
Synchronization Recovery and State Model Reduction for Soft Decoding of Variable Length Codes, IEEE Transactions on Information Theory, vol.53, issue.1, pp.368-377, 2007. ,
DOI : 10.1109/TIT.2006.887512
URL : https://hal.archives-ouvertes.fr/inria-00119600
Trellis state aggregation for soft decoding of variable length codes, IEEE Workshop on Signal Processing Systems Design and Implementation, 2005., pp.603-608, 2005. ,
DOI : 10.1109/SIPS.2005.1579937
Generalized Kraft Inequality and Arithmetic Coding, IBM Journal of Research and Development, vol.20, issue.3, pp.198-203, 1976. ,
DOI : 10.1147/rd.203.0198
Arithmetic coding algorithm with embedded channel coding, Electronics Letters, vol.33, issue.20, pp.1687-1688, 1997. ,
DOI : 10.1049/el:19971145
Integrating error detection into arithmetic coding, IEEE Transactions on Communications, vol.45, issue.1, pp.1-3, 1997. ,
DOI : 10.1109/26.554275
Image transmission using arithmetic coding based continuous error detection, Proceedings DCC '98 Data Compression Conference (Cat. No.98TB100225), pp.339-348, 1998. ,
DOI : 10.1109/DCC.1998.672162
Soft and Joint Source-Channel Decoding of Quasi-Arithmetic Codes, EURASIP Journal on Advances in Signal Processing, vol.2004, issue.3, pp.393-411, 2004. ,
DOI : 10.1155/S1110865704308085
An Introduction to Arithmetic Coding, IBM Journal of Research and Development, vol.28, issue.2, pp.135-149, 1984. ,
DOI : 10.1147/rd.282.0135
Asymptotic Error-Correcting Performance of Joint Source-Channel Schemes based on Arithmetic Coding, 2006 IEEE Workshop on Multimedia Signal Processing, pp.262-266, 2006. ,
DOI : 10.1109/MMSP.2006.285310
Practical Implementations of Arithmetic Coding, pp.85-112, 1992. ,
DOI : 10.1007/978-1-4615-3596-6_4
Finite state machine binary entropy coding, Proceedings of the Data Compression Conference (DCC '93), pp.449-459, 1993. ,
Source coding with channel, distorsion, and complexity constraints, EURASIP Journal on Advances in Signal Processing, issue.12, 1994. ,
Joint Source/Channel Coding and MAP Decoding of Arithmetic Codes, IEEE Transactions on Communications, vol.53, issue.6, pp.1007-1016, 2005. ,
DOI : 10.1109/TCOMM.2005.849690
Architecture and Construction of a Hardware Sequential Encoder for Speech, IEEE Transactions on Communications, vol.25, issue.7, pp.703-707, 1977. ,
DOI : 10.1109/TCOM.1977.1093894
Feedback Theory-Further Properties of Signal Flow Graphs, Proceedings of the Institute of Radio Engineers, pp.920-926, 1956. ,
DOI : 10.1109/JRPROC.1956.275147
URL : http://dspace.mit.edu/bitstream/1721.1/4778/1/RLE-TR-303-15342712.pdf
Iterative joint source-channel decoding of variable-length codes using residual source redundancy, IEEE Transactions on Wireless Communications, vol.4, issue.3, pp.919-929, 2005. ,
DOI : 10.1109/TWC.2005.847032
