Formal Modeling and Discrete-Time Analysis of BPEL Web Services - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Web services are increasingly used for building enterprise information systems according to the Service Oriented Architecture (SOA) paradigm. We propose in this paper a tool-equipped methodology allowing the formal modeling and analysis of Web services described in the BPEL language. The discrete-time transition systems modeling the behavior of BPEL descriptions are obtained by an exhaustive simulation based on a formalization of BPEL semantics using the Algebra of Timed Processes (ATP). These models are then analyzed by model checking value-based temporal logic properties using the CADP toolbox. The approach is illustrated with the design of a Web service for GPS navigation.
Mateescu-Rampacek-08.pdf (380.44 Ko) Télécharger le fichier
inria-00319100 , version 1 (05-09-2008)
Radu Mateescu, Sylvain Rampacek. Formal Modeling and Discrete-Time Analysis of BPEL Web Services. EOMAS 2008, Jun 2008, Montpellier, France. pp.179-193, ⟨10.1007/978-3-540-68644-6_13⟩. ⟨inria-00319100⟩
253 Consultations
276 Téléchargements
