6 2.3.1 Per-domain Path Computation ,
18 5.4.1 Parallelization and Complexity Reduction (pID-MCP) ,
EQ-BGP: an efficient inter-domain QoS routing protocol, 20th International Conference on Advanced Information Networking and Applications, Volume 1 (AINA'06), 2006. ,
DOI : 10.1109/AINA.2006.172
QoS Enhancements to BGP in Support of Multiple Classes of Service, MILCOM 2006, 2006. ,
DOI : 10.1109/MILCOM.2006.302080
Optimal configuration for BGP route selection, IEEE INFOCOM 2003. Twenty-second Annual Joint Conference of the IEEE Computer and Communications Societies (IEEE Cat. No.03CH37428), pp.916-926, 2003. ,
DOI : 10.1109/INFCOM.2003.1208929
On distinguishing between Internet power law topology generators, Twenty-First Annual Joint Conference of the IEEE Computer and Communications Societies (INFOCOM), pp.638-647, 2002. ,
Performance Analysis of Inter-Domain Path Computation Methodologies. draft-dasgupta-ccamp-path-comp-analysis-02, 2008. ,
A multiple quality of service routing algorithm for PNNI, 1998 IEEE ATM Workshop Proceedings. 'Meeting the Challenges of Deploying the Global Broadband Network Infrastructure' (Cat. No.98EX164), pp.324-328, 1998. ,
DOI : 10.1109/ATM.1998.675192
TAMCRA: a tunable accuracy multiple constraints routing algorithm, Computer Communications, vol.23, issue.7, pp.667-679, 2000. ,
DOI : 10.1016/S0140-3664(99)00225-X
RFC 4726: A Framework for Inter-Domain Multiprotocol Label Switching Traffic Engineering. IETF, 2006. ,
End-to-end quality of service provisioning through inter-provider traffic engineering, Computer Communications, vol.29, issue.6, pp.29683-702, 2006. ,
DOI : 10.1016/j.comcom.2005.07.022
Algorithms for finding paths with multiple constraints. Networks, pp.95-116, 1984. ,
Path Computation Architectures Overview in Multi-Domain Optical Networks Based on ITU-T ASON and IETF PCE, NOMS Workshops 2008, IEEE Network Operations and Management Symposium Workshops, pp.219-226, 2008. ,
DOI : 10.1109/NOMSW.2007.37
Topology aggregation and routing in bandwidth-delay sensitive networks, Globecom '00, IEEE. Global Telecommunications Conference. Conference Record (Cat. No.00CH37137), 2000. ,
DOI : 10.1109/GLOCOM.2000.892038
Multi-constrained optimal path selection, Proceedings IEEE INFOCOM 2001. Conference on Computer Communications. Twentieth Annual Joint Conference of the IEEE Computer and Communications Society (Cat. No.01CH37213), pp.834-843, 2001. ,
DOI : 10.1109/INFCOM.2001.916274
The impact of correlated link weights on QoS routing, IEEE INFOCOM 2003. Twenty-second Annual Joint Conference of the IEEE Computer and Communications Societies (IEEE Cat. No.03CH37428), pp.1425-1434, 2003. ,
DOI : 10.1109/INFCOM.2003.1208978
An overview of constraint-based path selection algorithms for QoS routing, IEEE Communications Magazine, vol.40, issue.12, pp.50-55, 2002. ,
DOI : 10.1109/MCOM.2002.1106159
Development of an Internet backbone topology for large-scale network simulations, Proceedings of the 2003 International Conference on Machine Learning and Cybernetics (IEEE Cat. No.03EX693), pp.694-702, 2003. ,
DOI : 10.1109/WSC.2003.1261485
Inter-domain routing: Algorithms for QoS guarantees, Computer Networks, vol.49, issue.4, pp.593-619, 2005. ,
DOI : 10.1016/j.comnet.2005.01.017
Path Selection Techniques to Establish Constrained Interdomain MPLS LSPs, Proceedings of Networking 2006, 2006. ,
DOI : 10.1109/90.650138
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.67.1135
A performance evaluation of BGP-based traffic engineering, International Journal of Network Management, vol.13, issue.3, pp.177-191, 2005. ,
DOI : 10.1002/nem.559
A MULTICONSTRAINT QOS ROUTING SCHEME USING A MODIFIED DIJKSTRA'S ALGORITHM, Networks, pp.65-76, 2002. ,
DOI : 10.1142/9789812776730_0006
Measuring ISP Topologies With Rocketfuel, IEEE/ACM Transactions on Networking, vol.12, issue.1, pp.2-16, 2004. ,
DOI : 10.1109/TNET.2003.822655
Service Level Agreements, p.8, 2008. ,
On Cooperative Inter-Domain Path Computation, 11th IEEE Symposium on Computers and Communications (ISCC'06), 2006. ,
DOI : 10.1109/ISCC.2006.109
Hop-by-hop quality of service routing, Computer Networks, vol.37, issue.3-4, pp.3-4407, 2001. ,
DOI : 10.1016/S1389-1286(01)00222-5
A scaling law for the hopcount in internet, 2000. ,
Concepts of Exact QoS Routing Algorithms, IEEE/ACM Transactions on Networking, vol.12, issue.5, pp.851-864, 2004. ,
DOI : 10.1109/TNET.2004.836112
RFC 5152: A Per-Domain Path Computation Method for Establishing Inter-Domain Traffic Engineering (TE) Label Switched Paths (LSPs) IETF, 2008. ,
Path Computation Element (PCE) Communication Protocol (PCEP). draft-ietf-pce-pcep-12, work in progress, 2008. ,
A Backward Recursive PCEbased Computation (BRPC) Procedure to Compute Shortest Constrained Inter-domain Traffic Engineering Label Switched Paths. draft-ietf-pce-brpc-09, work in progress, 2008. ,
Quality-of-service routing for supporting multimedia applications, IEEE Journal on Selected Areas in Communications, vol.14, issue.7, pp.1228-1234, 1996. ,
DOI : 10.1109/49.536364
QoS extension to BGP, 10th IEEE International Conference on Network Protocols, p.100, 2002. ,
MIRO: Multi-path Interdomain ROuting, ACM SIGCOMM, 2006. ,
Scalable BGP QoS Extension with Multiple Metrics, International conference on Networking and Services, 2006. ,
