SOFA - an Open Source Framework for Medical Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
SOFA is an Open Source framework primarily targeted at real-time simulation, with an emphasis on medical simulation. It is mostly intended for the research community to help develop newer algorithms, but can also be used as an efficient prototyping tool. Based on an advanced software architecture, it allows to: * create complex and evolving simulations by combining new algorithms with algorithms already included in SOFA * modify most parameters of the simulation - deformable behavior, surface representation, solver, constraints, collision algorithm, etc. - by simply editing an XML file * build complex models from simpler ones using a scene-graph description * efficiently simulate the dynamics of interacting objects using abstract equation solvers * reuse and easily compare a variety of available methods
MMVR07.pdf (623.92 Ko) Télécharger le fichier
Format : Figure, Image
inria-00319416 , version 1 (09-09-2008)
  • HAL Id : inria-00319416 , version 1
Jérémie Allard, Stéphane Cotin, François Faure, Pierre-Jean Bensoussan, François Poyer, et al.. SOFA - an Open Source Framework for Medical Simulation. MMVR 15 - Medicine Meets Virtual Reality, Feb 2007, Palm Beach, United States. pp.13-18. ⟨inria-00319416⟩
2398 Consultations
6204 Téléchargements
