Learning Color Names from Real-World Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Joost van de Weijer
  • Fonction : Auteur
  • PersonId : 847654
Cordelia Schmid
  • Fonction : Auteur
  • PersonId : 831154
Jakob Verbeek
Within a computer vision context color naming is the action of assigning linguistic color labels to image pixels. In general, research on color naming applies the following paradigm: a collection of color chips is labelled with color names within a well-defined experimental setup by multiple test subjects. The collected data set is subsequently used to label RGB values in real-world images with a color name. Apart from the fact that this collection process is time consuming, it is unclear to what extent color naming within a controlled setup is representative for color naming in real-world images. Therefore we propose to learn color names from real-world images. Furthermore, we avoid test subjects by using Google Image to collect a data set. Due to limitations of Google Image this data set contains a sub- stantial quantity of wrongly labelled data. The color names are learned using a PLSA model adapted to this task. Experimental results show that color names learned from real- world images significantly outperform color names learned from labelled color chips on retrieval and classification.
verbeek07cvpr2.pdf (1.45 Mo) Télécharger le fichier
VSV07.poster.pdf (1.68 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00321127 , version 1 (25-01-2011)
inria-00321127 , version 2 (11-04-2011)
Joost van de Weijer, Cordelia Schmid, Jakob Verbeek. Learning Color Names from Real-World Images. CVPR 2007 - IEEE Conference on Computer Vision & Pattern Recognition, Jun 2007, Minneapolis, United States. pp.1-8, ⟨10.1109/CVPR.2007.383218⟩. ⟨inria-00321127v2⟩
485 Consultations
2052 Téléchargements
