A Global Geometric Framework for Nonlinear Dimensionality Reduction, Science, vol.290, issue.5500, pp.2319-2323, 2000. ,
DOI : 10.1126/science.290.5500.2319
Nonlinear Dimensionality Reduction by Locally Linear Embedding, Science, vol.290, issue.5500, pp.2323-2326, 2000. ,
DOI : 10.1126/science.290.5500.2323
URL : http://astro.temple.edu/~msobel/courses_files/saulmds.pdf
Nonlinear Component Analysis as a Kernel Eigenvalue Problem, Neural Computation, vol.20, issue.5, pp.1299-1319, 1998. ,
DOI : 10.1007/BF02281970
Laplacian eigenmaps and spectral techniques for embedding and clustering, Advances in Neural Information Processing Systems, 2002. ,
Surface learning with applications to lipreading, Advances in Neural Information Processing Systems, 1994. ,
Global coordination of local linear models, Advances in Neural Information Processing Systems, 2002. ,
Automatic alignment of local representations, Advances in Neural Information Processing Systems, 2003. ,
Charting a manifold, Advances in Neural Information Processing Systems, 2003. ,
GTM: The Generative Topographic Mapping, Neural Computation, vol.39, issue.1, pp.215-234, 1998. ,
DOI : 10.1007/BF01889678
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.130.110
Self-organizing maps, 2001. ,
Learning high dimensional correspondences from low dimensional manifolds, ICML'03, workshop on the continuum from labeled to unlabeled data in machine learning and data mining, 2003. ,
How to measure the pose robustness of object views, Image and Vision Computing, vol.20, issue.4, pp.249-256, 2002. ,
DOI : 10.1016/S0262-8856(02)00006-9
