HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Procrustes analysis to coordinate mixtures of probabilistic principal component analyzers
Abstract : Mixtures of Probabilistic Principal Component Analyzers can be used to model data that lies on or near a low dimensional manifold in a high dimensional observation space, in effect tiling the manifold with local linear (Gaussian) patches. In order to exploit the low dimensional structure of the data manifold, the patches need to be localized and oriented in a low dimensional space, so that local coordinates on the patches can be mapped to global low dimensional coordinates. As shown by [Roweis et al., 2002], this problem can be expressed as a penalized likelihood optimization problem. We show that a restricted form of the Mixtures of Probabilistic Principal Component Analyzers model allows for an efficient EM-style algorithm. The Procrustes Rotation, a technique to match point configurations, turns out to give the optimal orientation of the patches in the global space. We also show how we can initialize the mappings from the patches to the global coordinates by learning a non-penalized density model first. Some experimental results are provided to illustrate the method.
Document type :
Reports
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/inria-00321503
Contributor : Jakob Verbeek Connect in order to contact the contributor
Submitted on : Wednesday, February 16, 2011 - 5:10:17 PM
Last modification on : Monday, September 25, 2017 - 10:08:04 AM
Long-term archiving on: : Tuesday, May 17, 2011 - 2:33:35 AM
verbeek02tr2.pdf
Identifiers
  • HAL Id : inria-00321503, version 1
Collections
Citation
Jakob Verbeek, Nikos Vlassis, Ben Krose. Procrustes analysis to coordinate mixtures of probabilistic principal component analyzers. [Technical Report] IAS-UVA-02, 2002, pp.18. ⟨inria-00321503⟩
Share
Metrics
Record views
140
Files downloads
143
