Abstract : We propose an incremental method to find principal curves. Line segments are fitted and connected to form polygonal lines. New segments are inserted until a performance criterion is met. Experimental results illustrate the performance of the method compared to other existing approaches.
https://hal.inria.fr/inria-00321517 Contributor : Jakob VerbeekConnect in order to contact the contributor Submitted on : Wednesday, February 16, 2011 - 5:02:29 PM Last modification on : Monday, September 25, 2017 - 10:08:04 AM Long-term archiving on: : Tuesday, May 17, 2011 - 2:38:20 AM
Jakob Verbeek, Nikos Vlassis, Ben Krose. A k-segments algorithm for finding principal curves. [Technical Report] IAS-UVA-00-11, 2000, pp.12. ⟨inria-00321517⟩
