New interface
Conference papers
Ontology Learning from Text using Relational Concept Analysis
Abstract : We propose an approach for semi-automated construction of ontologies from text whose core component is a Relational Concept Analysis (RCA) framework which extends Formal Concept Analysis (FCA), a lattice-theory paradigm for discovering abstractions within objects x attributes tables, to the processing of several sorts of individuals described both by own properties and inter-individual links. As a pre-processing, text analysis is used to transform a document collection into a set of data tables, or contexts, and inter-context relations. RCA then turns these into a set of concept lattices with inter-related concepts. A core ontology is derived from the lattices in a semi-automated manner, by translating relevant lattice elements into ontological concepts and relations, i.e., either taxonomic or transversal ones. The ontology is further refined by abstracting new transversal relations from the initially identified ones using RCA. The results of an initial validation of the approach through an application to astronomy texts are reported.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00322007
Contributor : Mohamed Rouane-Hacene Connect in order to contact the contributor
Submitted on : Tuesday, September 16, 2008 - 2:15:38 PM
Last modification on : Tuesday, September 6, 2022 - 4:54:01 PM
Identifiers
  • HAL Id : inria-00322007, version 1
Citation
Amine Mohamed Rouane Hacene, Amedeo Napoli, Petko Valtchev, Yannick Toussaint, Rokia Bendaoud. Ontology Learning from Text using Relational Concept Analysis. International MCETECH Conference on e-Technologies - MCETECH 2008, Jan 2008, Montréal, Canada. ⟨inria-00322007⟩
Share
Metrics
Record views
127
