Using Structural Recursion for Corecursion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
Yves Bertot
We address the problem of constructing stream values de- fined by recursive equations that do not respect directly the “guarded- ness” condition, and we concentrate in particular on equations where recursive call appear under functions. We use a correspondence between streams and functions over natural numbers to show that some classes of non-guarded definitions can still be modelled through the encoding as structural recursive functions. In practice, this work extends the class of stream values that can be defined in a constructive type theory-based theorem prover with inductive and coinductive types, structural recursion and guarded corecursion.
fibonacci.pdf (181.73 Ko) Télécharger le fichier
modcorec.v (2.74 Ko) Télécharger le fichier
Format : Autre
inria-00322331 , version 1 (17-09-2008)
inria-00322331 , version 2 (18-09-2008)
inria-00322331 , version 3 (22-09-2008)
inria-00322331 , version 4 (23-03-2009)
  • HAL Id : inria-00322331 , version 2
Yves Bertot, Ekaterina Komendantskaya. Using Structural Recursion for Corecursion. 2008. ⟨inria-00322331v2⟩
323 Consultations
619 Téléchargements
