New interface
Reports (Research report)
Efficient Mining of Frequent Closures with Precedence Links and Associated Generators
Laszlo Szathmary 1, 2, * Petko Valtchev 2 Amedeo Napoli 1
* Corresponding author
1 ORPAILLEUR - Knowledge representation, reasonning
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : The effective construction of many association rule bases require the computation of frequent closures, generators, and precedence links between closures. However, these tasks are rarely combined, and no scalable algorithm exists at present for their joint computation. We propose here a method that solves this challenging problem in two separated steps. First, we introduce a new algorithm called Touch for finding frequent closed itemsets (FCIs) and their generators (FGs). Touch applies depth-first traversal, and experimental results indicate that this algorithm is highly efficient and outperforms its levelwise competitors. Second, we propose another algorithm called Snow for extracting efficiently the precedence from the output of Touch. To do so, we apply hypergraph theory. Snow is a generic algorithm that can be used with any FCI/FG-miner. The two algorithms, Touch and Snow, provide a complete solution for constructing iceberg lattices. Furthermore, due to their modular design, parts of the algorithms can also be used independently.
Document type :
Complete list of metadata
Cited literature [26 references]  Display  Hide  Download
https://hal.inria.fr/inria-00322798
Contributor : Laszlo Szathmary Connect in order to contact the contributor
Submitted on : Thursday, September 18, 2008 - 9:06:45 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:07 AM
Long-term archiving on: : Tuesday, September 21, 2010 - 5:51:47 PM
File
RR-6657.pdf
Identifiers
  • HAL Id : inria-00322798, version 2
Collections
Citation
Laszlo Szathmary, Petko Valtchev, Amedeo Napoli. Efficient Mining of Frequent Closures with Precedence Links and Associated Generators. [Research Report] RR-6657, INRIA. 2008, pp.58. ⟨inria-00322798v2⟩
Share
Metrics
Record views
116
Files downloads
159
