Reports
Conditional stability for ill-posed elliptic Cauchy problems : the case of Lipschitz domains (part II)
Laurent Bourgeois 1 Jérémi Dardé 1
1 POEMS - Propagation des Ondes : Étude Mathématique et Simulation
Inria Saclay - Ile de France, UMA - Unité de Mathématiques Appliquées, CNRS - Centre National de la Recherche Scientifique : UMR7231
Abstract : This paper is devoted to a conditional stability estimate related to the ill-posed Cauchy problems for the Laplace's equation in domains with Lipschitz boundary. It completes the results obtained in \cite{bourgeois1} for domains of class $C^{1,1}$. This estimate is established by using an interior Carleman estimate and a technique based on a sequence of balls which approach the boundary. This technique is inspired from \cite{alessandrini}. We obtain a logarithmic stability estimate, the exponent of which is specified as a function of the boundary's singularity. Such stability estimate induces a convergence rate for the method of quasi-reversibility introduced in \cite{lions} to solve the Cauchy problems. The optimality of this convergence rate is tested numerically, precisely a discretized method of quasi-reversibility is performed by using a nonconforming finite element. The obtained results show very good agreement between theoretical and numerical convergence rates.
Document type :
Reports
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/inria-00324166
Contributor : Laurent Bourgeois Connect in order to contact the contributor
Submitted on : Wednesday, September 24, 2008 - 11:26:53 AM
Last modification on : Wednesday, May 11, 2022 - 12:06:04 PM
Long-term archiving on: : Tuesday, June 28, 2011 - 4:48:11 PM
File
RR-6588.pdf
Identifiers
  • HAL Id : inria-00324166, version 1
Citation
Laurent Bourgeois, Jérémi Dardé. Conditional stability for ill-posed elliptic Cauchy problems : the case of Lipschitz domains (part II). [Research Report] RR-6588, INRIA. 2008. ⟨inria-00324166⟩
Share
Metrics
Record views
110
Files downloads
64
