Generic Self-calibration of Central Cameras from Two “Real” Rotational Flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The generic central camera model can describe any imaging system with a single effective viewpoint. We are interested in the self-calibration of this model from only two rotations about non co-linear axes. Concisely, we show that the theoretical solution given in [1] performs correctly with real flow data, and that a simple iterative process can be used to improve the camera motion estimation. A method for the computation of smooth dense generic flows from rotational images is also presented and used in our experiments to compute “real” flows from both simulated and real images.
A15CR.pdf (3.47 Mo) Télécharger le fichier
inria-00325325 , version 1 (28-09-2008)
  • HAL Id : inria-00325325 , version 1
Ferran Espuny, Jose I. Burgos Gil. Generic Self-calibration of Central Cameras from Two “Real” Rotational Flows. The 8th Workshop on Omnidirectional Vision, Camera Networks and Non-classical Cameras - OMNIVIS, Rahul Swaminathan and Vincenzo Caglioti and Antonis Argyros, Oct 2008, Marseille, France. ⟨inria-00325325⟩
Collections
OMNIVIS2008
119 Consultations
147 Téléchargements
