Auto-Organized Visual Perception Using Distributed Camera Network
Abstract : Camera networks are complex vision systems difficult to control if the number of sensors is getting higher. With classic approaches, each camera has to be calibrated and synchronized individually. These tasks are often troublesome because of spatial constraints, and mostly due to the amount of information that need to be processed. Cameras generally observe overlapping areas, leading to redundant information that are then acquired, transmitted, stored and then processed. We propose in this paper a method to segment, cluster and codify images acquired by cameras of a network. The images are decomposed sequentially into layers where redundant information are discarded. Without need of any calibration operation, each sensor contributes to build a global representation of the entire network environment. The information sent by the network is then represented by a reduced and compact amount of data using a codification process. This framework allows structures to be retrieved and also the topology of the network. It can also provide the localization and trajectories of mobile objects. Experiments will present practical results in the case of a network containing 20 cameras observing a common scene.
Type de document :
Communication dans un congrès
The 8th Workshop on Omnidirectional Vision, Camera Networks and Non-classical Cameras - OMNIVIS, Oct 2008, Marseille, France. 2008
Liste complète des métadonnées
Littérature citée [16 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00325384
Contributeur : Peter Sturm <>
Soumis le : lundi 29 septembre 2008 - 10:42:40
Dernière modification le : jeudi 22 novembre 2018 - 14:26:46
Document(s) archivé(s) le : vendredi 4 juin 2010 - 11:53:50
Fichier
A41CR.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : inria-00325384, version 1
Citation
Richard Chang, Sio-Hoi Ieng, Ryad Benosman, Loïc Lachèze, Thibaud Debaecker. Auto-Organized Visual Perception Using Distributed Camera Network. The 8th Workshop on Omnidirectional Vision, Camera Networks and Non-classical Cameras - OMNIVIS, Oct 2008, Marseille, France. 2008. 〈inria-00325384〉
Métriques
Consultations de la notice
554
Téléchargements de fichiers
110
