Multi-target tracking with occlusion management in a mean field framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
C. Medrano
  • Fonction : Auteur
R. Igual
  • Fonction : Auteur
J. Martinez
  • Fonction : Auteur
C. Orrite
  • Fonction : Auteur
In this paper we consider the problem of tracking multiple targets. Following a mean field approach, we obtain a cost function that depends on the means and covariances of each object. A simplification of this cost function leads to self consistent equations for the means, while the covariances are obtained using a normal Kalman filter. The iteration of the self consistent equations allows refining the solution and including the effect of occlusions. An implicit assumption of our model is that we can deduce the depth order from the joint state and that we can approximate the posterior of each object by a Gaussian. We show how this simple approach reduces the number of tracking failures in two sequences. The first one is a synthetic sequence of tennis balls moving on a background. The second one is a sequence of a football match taken from the VS-PETS data base.
VS2008-Poster-c.pdf (218.23 Ko) Télécharger le fichier
inria-00325771 , version 1 (30-09-2008)
  • HAL Id : inria-00325771 , version 1
C. Medrano, R. Igual, J. Martinez, C. Orrite. Multi-target tracking with occlusion management in a mean field framework. The Eighth International Workshop on Visual Surveillance - VS2008, Graeme Jones and Tieniu Tan and Steve Maybank and Dimitrios Makris, Oct 2008, Marseille, France. ⟨inria-00325771⟩
Collections
VS2008
58 Consultations
70 Téléchargements
