A Bayesian approach to image expansion for improved definition, IEEE Transactions on Image Processing, vol.3, issue.3, pp.233-242, 1994. ,
DOI : 10.1109/83.287017
Super-Resolved Surface Reconstruction from Multiple Images, pp.293-308, 1996. ,
DOI : 10.1007/978-94-015-8729-7_23
Joint MAP registration and high-resolution image estimation using a sequence of undersampled images, IEEE Transactions on Image Processing, vol.6, issue.12, pp.1621-1633, 1997. ,
DOI : 10.1109/83.650116
Bayesian image super-resolution, Neural Information Processing Systems, 2002. ,
Example-based super-resolution, IEEE Computer Graphics and Applications, vol.22, issue.2, pp.56-65, 2002. ,
DOI : 10.1109/38.988747
Fast Transformation-Invariant Component Analysis, International Journal of Computer Vision, vol.27, issue.1, pp.1-3, 2008. ,
DOI : 10.1007/s11263-007-0094-4
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.110.8553
Fundamental limits of reconstruction-based superresolution algorithms under local translation, IEEE Trans. on Pattern Analysis and Machine Intelligence, vol.26, issue.1, pp.83-97, 2004. ,
Bayesian image superresolution , continued, Neural Information Processing Systems, 2006. ,
Penrose Pixels Super-Resolution in the Detector Layout Domain, 2007 IEEE 11th International Conference on Computer Vision, 2007. ,
DOI : 10.1109/ICCV.2007.4408888
Optimizing and learning for superresolution, Proc. of the British Machine Vision Conference, pp.439-448, 2006. ,
Limits on super-resolution and how to break them, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.9, pp.1167-1183, 2002. ,
DOI : 10.1109/TPAMI.2002.1033210
Learning low-level vision, Proceedings of the Seventh IEEE International Conference on Computer Vision, pp.25-47, 2000. ,
DOI : 10.1109/ICCV.1999.790414
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.116.8559
Limits of learning-based superresolution algorithms, Proc. IEEE Int. Conf. on Computer Vision, 2007. ,
Sparse Bayesian learning and the relevance vector machine, J. of Machine Learning Research, vol.1, pp.211-244, 2001. ,
Maximum likelihood from incomplete data via the EM algorithm, J. Roy. Statist. Soc. B, vol.39, pp.1-38, 1977. ,
