THE EFFECT OF SPEECH AND AUDIO COMPRESSION ON SPEECH RECOGNITION PERFORMANCE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
This paper proposes an in-depth look at the influence of different speech and audio codecs on the performance of our continuous speech recognition engine. GSM full rate, G711, G723.1 and MPEG coders are investigated. It is shown that MPEG transcoding degrades the speech recognition performance for low bitrates whereas performance remains acceptable for specialized speech coders like GSM or G711. A new strategy is proposed to cope with degradation due to low bitrate coding. The acoustic models of the speech recognition system are trained with transcoded speech (one acoustic model for each speech / audio codec). First results show that this strategy allows to recover acceptable performance.
Besacier01b.pdf (45.38 Ko) Télécharger le fichier
inria-00326165 , version 1 (02-10-2008)
  • HAL Id : inria-00326165 , version 1
Laurent Besacier, Carole Bergamini, Dominique Vaufreydaz, Eric Castelli. THE EFFECT OF SPEECH AND AUDIO COMPRESSION ON SPEECH RECOGNITION PERFORMANCE. IEEE Multimedia Signal Processing Workshop, IEEE, Oct 2001, Cannes, France. pp. 301-306. ⟨inria-00326165⟩
97 Consultations
1062 Téléchargements
