Optimizing Trajectories Clustering for Activity Recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This work aims at recognizing activities from large video datasets, using the object trajectories as the activity descriptors. We make usage of a compact structure based on 6 features to represent trajectories. This structure allows us to apply standard techniques for unsupervised clustering. We present a method to optimize trajectory clustering by tuning the set of trajectory feature weights in order to improve the performance of activity recognition. We have learned the weights and test the approach using different sets of real video data achieving domain knowledge independence. Moreover we define new performance measures that better describes the evaluation of the clustering process comparing the learned clusters with activity ground truth.
mlvma08_submission_19.pdf (704.38 Ko) Télécharger le fichier
inria-00326718 , version 1 (05-10-2008)
  • HAL Id : inria-00326718 , version 1
Guido Pusiol, Luis Patino, François Bremond, Monique Thonnat, Sundaram Suresh. Optimizing Trajectories Clustering for Activity Recognition. The 1st International Workshop on Machine Learning for Vision-based Motion Analysis - MLVMA'08, Oct 2008, Marseille, France. ⟨inria-00326718⟩
117 Consultations
117 Téléchargements
